s13_240_rb20 »
https://forums.nicoclub.com/s13-240-rb20-u87143.html
Wed Mar 11, 2009 12:11 am
Well, today marks the first official day of this project. I planned on using my 5sp hardbody for the RB20 swap, but quickly changed my mind and decided on using my automatic 1993 hardbody for the project.
The motor & transmission are now out of the truck and sitting neatly aside on a pallet as spare parts for my other hardbody. I will try to be brief but hopefully I won't leave anything out about each stage of the project:
TO PULL THE AUTOMATIC MOTOR/TRANSMISSION SETUP:
(note 1: you will have to search for everything when I generally say to unhook stuff)(note 2: if you are replacing with another KA, you can remove the ac compresser and PS pump without disconnecting hoses, i think)
1. unplug the spark plug wires, injector plugs, and EVERY plug on that harness.2. unplug/unhook every ground/wire/plug connecting the motor to anything that will stay on the fenderwells/firewall/etc when you pull it(if you miss anything, you will find it and unhook it when you try to lift the motor/tranny out)3. unplug/unhook all sensor wires on the transmission4. disconnect the two coolant lines running to the bottom of the radiator5. unhook the two power steering lines and replace the bolts with the rings (in case you sell the part or need it later)6. slowly loosen the ac lines from the ac compressor and once releasing, let it completely evacuate before returning to the area, then unhook and replace the bolts.7. remove the top radiator mounts, radiator with shroud, and radiator hoses, then loosely replace the screws and mounts8. unhook the shifter (pointing down) from the auto tranny by removing the cotter pin and bolt, remove, then replace the pin/bolt9. remove the several bolts holding the exhaust manifold on (or saw off the exhaust) and the pipe going into your exhaust manifold from behind the motor if you chose NOT to cut off the exhaust below that point(insert step 16 if you want but it's easier later)10. break loose all 4 of the motor mounts where they bolts to the frame but leave them there11. remove the 2 nuts on the middle of the tranny crossmember12. use a jack and block of wood to support the transmissions weight13. oh yeah, either drain your ATF now or ALL of your ATF will spill out when pulling the engine/tranny14. after supporting carefully, use a wrench on top to hold the bolts and remove the 4 bolts/nuts securing the outsides of the tranny crossmember15. remove the loosened bolts holding the motor mounts to the frame16. after carefully hooking up your hoist (make sure you aren't snagging the exhaust pipe if NOT cut), lift the motor about 5 inches and remove the heater core lines after your motor sways forward17. Look for ALL other snags/plugs/wires still connecting your motor/tranny to the truck and disconnect them18. If all else is unhooked then pry off your exhaust if you didn't cut it off from the exhaust system19. Lower and remove the jack from under the transmission (it will start leaking out the remaining fluid once disconnected from the driveshaft)20. slowly, gently, and carefully lift out the engine/tranny and watch out for missed components that need disconnecting
Unless I missed anything, that is how to pull an automatic KA & tranny in 20 steps (or less if you cut off the exhaust)
Now is the time to scrub your engine bay if appearance and showmanship matters to you, or perform maintenance on ANYTHING that needs it that is still there.
TO CONVERT AN AUTOMATIC TO A 5SPEED
I removed the clutch pedal, brake pedal, clutch master cylinder, clutch slave cylinder, their connecting hardline from the firewall, and all of the 5sp floor shifter parts from a junkyard 5speed.
It's pretty easy when you get to demolish the dash and the air vent behind the dash on a junked truck. Only about 20 bolts, I think, and you could take the time to do it right.
I'll be returning to tell you about installing these parts!!! SEE YOU AFTER THE RAIN STOPS!!
--TJ
Modified by s13_240_rb20 at 6:22 AM 3/24/2009
