Sorry man, i dont have "live" pictures of my motor to show you. I wish I took pictures of my build so I could construct a database like driftopia did for the ca18. Anyways, heres a picture of the fsm. I circled the vacuum ports in red:
-The port on the left, (front of motor) is for the fuel pressure regulator.
-The next port is under the throttle body. If youre not using a charcoal canister (like me) just block it off. I just cut a small piece of hose and plugged it with a small screw.
-The next 2 are inches from each other, on the side of the manifold, by the throttle body (you can see the bov connected to one of them). If youre not using a charcoal canister, block one of them off. The other is a vacuum source for the bov. If youre not using a bov, just cap it off as well.
-The last 2 are in the back. The large port is for the black master cylinder, and the very thin one is a miscellaneous vacuum port. I think it was for the oem boost gauge, Im using it for my aftermarket boost gauge. Do what you will with it, but if you dont need it, cap it off as well.
Hope that helps a little.
