Code: Select all
PART JDM / RB20DET # USDM / KA24DE / VG30xxxx #--------------------------------------------------------------------------------------------------N1 Oil pump 15010-24U01
Oil filter 15208-00003 (KA24DE) Genuine Nissan 15208-H8911 (AUS) Genuine Nissan 15208-H8904 Ryco Z145A Valvoline R9
Fuel filter 16400-53J10 16400-00002 (VG30DE, VG30DETT)***Subaru Forester filter works
Fuel pump 17042-00003 (VG30DETT)
Fuel injectors Denso 440cc 195500-2010 non-turbo, 1989-1991 Mazda RX7 Denso 550cc 195500-2020 turbo, 1989-1991 Mazda RX7
Thermostat 21200-42L00 21200-00001 (VG30DE, VG30DETT)Nismo Thermostat 21200-42L05
Clutch***1990-1996 VG30DE shares same clutch assembly
Spark plugs 22401-000036 (VG30DE, VG30DETT???) NGK standard 1.1mm PFR5A-11 NGK Iridium 0.8mm T7341T-8 Trust-Greddy Iridium 0.8mm IT08
Water pump 21010-21T25 N1 21010-24U27
Coil packs 22433-60U02***RB20DE, RB20DET, VG30DE, VG30DETT, RB25DE share same coil packs ???
Rod bolts ARP 202-6005 ???
O2 sensor (which one?) 22690-73L11
Alternator belt 11720-24U00Timing belt 13028-20P10 13028-20P25 (boxed)Power steering belt 11950-04U00AC belt 11920-42L01Fan belt ??? 11720-42L02
Sump washer 11026-01M02
Air flow meter 22680-02U00
Speedo drive gearbox end 32702-58S21
