Razi has got boost!
Razi
Car: Moo
Edit : If you're reading this right now and you're on dial-up. Go run 3 miles and come back, this thread has a TON of pictures.Some of you know I've been thinking of going KA-T about a month ago.Well, I have. <IMG NAME="icon" SRC="http://images.nicoclub.com/forums/image ... /smile.gif" BORDER="0"> and it's done.Me and my dad did the all work in our little garage and it purrs like a kitten.
Enough talk!!MOAR PICTURES.
Here is my blacked out intercooler. Stealthy!
Turbo
BOV flange welded by a local guy.
Oil pan bung welded and painted.
Took off the oil pan and took a peak up my engine. Cleaan.
If you ever want to take off the oil pan, this is how I did it.First, undo the motor mounts.Then lift up the transmission here.Keep lifting and you should see this.Also there are 2 triangle braces where the transmission and engine meet, take that off, then you can access the rest of the oil pan bolts.Then remove the oil pick up and slide it out, if it gets stuck, lift it some more.It looks like this when you're done.
Enough article-esque chit-chat.More turbo related pictures!Everything! Those are turbo coolant lines running in front of the engine.Close up of how they are run. I took the coolant lines away from the throttle body and ran it over to the turbo. The black thing is a slice of rubber hose to keep the lines from "taptaptaptaptap"ing against each other as I drive.The coolant line from the engine and the line from the turbo are joined by a hose, this let me flex the piping around to find a good spot for them to sit on.The coolant feed part is like this too.Makes installing things easier too, if you put the hose area in a good place.This is how my FMU is mounted on my strut bar.Wrapped the AC line so I don't catch on fire on the freeway. Also I tapped the intercooler piping for my wastegate.Miata batteryRecirculated BOV + pink hose for added hp.Black thingy is my water temp sensor Tee.Wrapped exhaust stuff, with my oil sandwich block + oil pressure sensor and turbo oil feed line.Better shot of the oil sandwich, I angled the oil T on purpose.Also I found out it leaks, but I tightened it yesteday and put in thicker oil today, I hope it doesn't leak again -_-.Difficult to see the intercooler even with camera flash. (That grill was made by my dad.And finally, my gauges and new black dash.
My car sounds nice, but looks stock... someone donate me skirts and a bumper.
Oh yeah how could I forget.MAJOR props to 480sx, WDRacing, spooled240, and a ton of other people for helping me out with the knowledge I needed for this build, and answering my noob questions.Also, DJButton for sending me oil fittings I needed :D
Modified by Razi at 3:47 PM 3/12/2010
sommmatt
Car: 1989 Nissan 240SX
Ballllin! It needs to be warmer so I can do the same thing. Got the parts, but I'm breaking too many tools in the cold, lol.
Razi
Car: Moo
Give me rear coupe valences and OEM skirts and I'll let you live in my garage and work on your car.
California weather ftw.
Dittoz7
Car: 1997 2f0WtY SE!
Nice!
Sound Clip Or Ban!
cavepiggy623
Car: 1990 240sx coupe 2000 Altima
very nice. i cant wait to get out of college and start my build.
gmac708
Car: :o)
1970 Datsun 240Z
1972 Datsun 510
way to go Razi Looks real nice. I like the black intercooler, you got Ninja skills
MastaYu
Car: 92 Nissan 240SX SE HB
Very nice boost
Razi
Car: Moo
A more recent picture of the bay. Don't worry I didn't lose my fuse box cover.
Thanks everyone for the kind words.
s14derrick
Car: 1995 nissan 240sx
black intercooler huh? what brand is it. i always wanted a black core over a non black core lol
Razi
Car: Moo
I painted it black, it's a CXracing intercooler though.
I got the SR version cause they charge a ton more for the KA version.Fitment of the piping is really crappy of course.But the INTERCOOLER, fit like crap.Me and my dad had to bend the brackets that came with it and drill holes in them to make em fit.
Speaking of things that dont fit.I bought the manifold, turbo elbow, and downpipe all from Megan so everything bolt together.
It did.Except my engine sits a little high and the flex section on the downpipe hit my car's belly and wouldn't fit. It's like Megan got a normal downpipe and just welded in a flex section and called it a day without making it sit lower to compensate for the fatter flex section. Thank goodness the muffler guy is good at his job.
E7-S14
Car: ess 14 foo!
beautiful!dam manima have to get on the role and boost my baby already...
s14derrick
what all did you have to do to get the intercooler piping to work on the ka?not much of a selection for ka-t guys
Razi
Car: Moo
E7-S14 wrote:beautiful!dam manima have to get on the role and boost my baby already...
Haha thanks.
s14derrick wrote:what all did you have to do to get the intercooler piping to work on the ka?not much of a selection for ka-t guys
A lot of muscling around and cutting the top part of the silicone on the throttle body side, so the bottom part of the silicone could slip in. It was at an akward angle. Hard to explain.
The cold side was abnormally high since I have a GT28 and it's compressor elbow is at a different angle than a T25. I cut a part of the pipe off and that let me close the hood but it's still slightly touching. Also me and my dad had to muscle things around ALOT. Ugh.
boostdd
Car: 97 s14/ r1
Nice setup up , how much u end up spending ? What engine management u running ?
Razi
Car: Moo
$3k since I bought a brand new S15 GT28R turbo.
Fuel management for now is a 8:1 Vortech FMU.
Larger injectors and a tune would be nice but no more $$$$$ right now, plus it runs fine at the moment so I'm not in a hurry.
If anyone can see something funky about my air intake, you get a cookie.
shanelach
Car: N/A
Looking good! I need to get more guap and start a rebuild on the side for boost.. Stock air box? maybe a cone inside?
nifares240
Car: 1993 240sx Black-Project Car, 1993 240sx Red-SOLD, 1994 Sentra, 2004 Nissan Sentra SE-R SPEC V-Daily, 1999 Toyota Camry
I have about 3k for my turbo...but saving some more for about 5k. looks great man!
ka-t all the way.
keep it looking stock so it will be a sleeper. but to each of his own. nice
Logan76
Car: Junk
stock air box? You must have incredible spool with that GT28 on the KA, what rpm are you getting full spool?
spank044
Car: 1992 240sx with a Supercharged 350Z VQ for a HEART!
Way to go bud, welcome to the KA-T family. How about a few more specs. Boost, spool time/ rpm, and the technical stuff.
Razi
Car: Moo
nifares240 wrote:keep it looking stock so it will be a sleeper. but to each of his own. nice
Yep I'm keeping it looking stock for now, that's why I used a OEM Nissan airbox.
Logan76 wrote:stock air box? You must have incredible spool with that GT28 on the KA, what rpm are you getting full spool?
Can't use all 8 psi right now, stock clutch slips LOL.
I can make it start spooling below 3k at a bit more than half throttle.
For the box, I used a Nissan Altima box chopped most of the bottom out so it sits lower. Then I modified the air box some more and flipped the MAF upside down so it clears the intercooler piping.
spank044 wrote:Way to go bud, welcome to the KA-T family. How about a few more specs. Boost, spool time/ rpm, and the technical stuff.
:D thanks.
Boost : 8 psi, only can use 5 psi before clutch slips.Spool time : Really quick, makes boost fairly quickly without even flooring it at around 3k.
mattblancarte
Car: 2005 BMW M3 Comp. Coupe
The exhaust manifold looks AWESOME. Lovin' it. Congrats on the new boost!
hbpignosePA
Car: 90 240sx hatch (Jackstand Queen)
78 Datsun 280Z (RIP)
89 Toyota Cressida (Sold)
86 Nissan 200SX hatch (sold)
83 Nissan 280ZX turbo (parts car)
90 Volvo 240 (sold)
80 Toyota Cressida MX32 (new daily)
clean as always razi
mRodiek
Car: Stock Hatch
CONGRATS! when's the dyno sheet coming? boost is Addicting!!lol was the piping from CXracing as well? i want some black IC piping but cant find any for a front mount. or did you paint that as well?
Razi
Car: Moo
mattblancarte wrote: The exhaust manifold looks AWESOME. Lovin' it. Congrats on the new boost!
It was changing colors everytime I drive it. LOL it's fun to guess the next color.
hbpignosePA wrote:clean as always razi
Thanks :D As always huh?
DriftBoy07 wrote:CONGRATS! when's the dyno sheet coming? boost is Addicting!!lol was the piping from CXracing as well? i want some black IC piping but cant find any for a front mount. or did you paint that as well?
Dunno if I will put it on a dyno yet.Yes piping is from CXracing, it was very hard to fit.And I painted them black.
Also guys, disregard my previous posts on when it spools. I've only driven it a couple of times and I forgot.
I just came back from driving it to Golden Chopsticks ( ) and unless I drive very slow, I can set off the BOV below 2.5k revs HAHA.
vrooooooooooom pshh
mRodiek
Car: Stock Hatch
vrooooooooooom pshh
sexxxy. whered you get your S15 turbo, is it the Spec-R one? im upgrading on my SR
Razi
Car: Moo
FRsport.com, on their Thanksgiving special discount.
I've been overheating these days and now I figured out a small crack in the radiator turned into a huge one, no clue how I didn't notice since it's on the top of the radiator.
Now I need to find a replacement or find a way to fix it .
TheOne
Car: 93 240sx FB
very nice setup, looks very clean, now get a new clutch, bigger injectors and some sort of ecu to turn up the boooost!
hbpignosePA
90 Volvo 240 (sold)
well your craftiness reflexs your posts on the boards... thought out and not full of fail
DriftX
Car: '89 240sx
I don't see a wideband anywhere.
Word of advice, ditch the FMU and get a wideband and rom tune.
contact Carl H for more info, he's done some tuning for me, A+++ stuff.
Razi
Car: Moo
hbpignosePA wrote:well your craftiness reflexs your posts on the boards... thought out and not full of fail
DriftX wrote:I don't see a wideband anywhere.
Don't worry, KA-T guys have ran FMU setups for T25/T28s for a while with no problems, it's a well known reliable setup.
Bigger injectors and a tune is somewhere in the future though.
