Probably because they are bigger than anniversary wheels and LMGT4s. They are 18x9 and 19x10. I love that kind of setup...NolimitZ32 wrote:I think those look better then the anniversary wheels and not nearly as played out as the LMGT4s
Do it.hawaiiski wrote:What do you guys think?
Hahah I want to do this but as of right now I won't have a job till summercar nut wrote:
Do it.
When I get home i'll check them out and If I don't like them ill probably put them up here for sale so i'll let you know. But as of right now I like the look just hadn't seen it in person yet.LUCKYZ wrote:I've been searching for a set of those wheels.
What size tires you got on there that are rubbing? Stock sizes? Plz tell me you are just holding on to them until you either get different tires or spacers to stop the rubbing...hawaiiski wrote: We tried to put the V2's on the vert but they rubbed to much so we went back to the M-sports.
I suppose that's possible. If there's no pressure left in the shock, then there's nothing to keep the spring from depressing under the weight of the engine. Are you using lowering springs with stock shocks?hawaiiski wrote:Question...Would having blown shocks affect the height of the car? Can't remember the last time I replaced them.
I'd switch to a lower profile tire and/or dial in a little negative camber at this point, before I moved to more major fender work like trimming stuff. But thats just me.hawaiiski wrote:im pretty sure it was just rubbing on the liner and maybe a little on the corner of the bumper when turning. The back was fine it was the front that was the trouble, so I think it would only be a little trimming.
Typically if they are blown then it will most definitely affect your ride height.hawaiiski wrote:Question...Would having blown shocks affect the height of the car? Can't remember the last time I replaced them. Because trust me we tried, im pretty sure it was just rubbing on the liner and maybe a little on the corner of the bumper when turning. The back was fine it was the front that was the trouble, so I think it would only be a little trimming.
Now just a little drophawaiiski wrote:Like I said once i get home ill post some pictures for you guys.
I bet it will still rub once you drop it until you get some less tall front tires... Looks good though.hawaiiski wrote:Now just a little drop
