I would have it checked out as it could be a bearing associated with the clutch. The fact that it goes away when pushed in typically would not indicate this however. The can be anything from normal transmission noise especially if running an aftermarket flywheel and or clutch combination or it could indicate something like a pilot shaft bearing problem.otaku1010 wrote:i have a 04 g35 coupe 6mt and when im idling the car rattle underneath, but when i push the clutch in the rattle goes away. whats wrong? someone told me it could be my throttle bearing...is this true and if so how much does it cost to replace and can i do it myself? thanks
Hard to state that his sound is normal without hearing it personally. It very well be that he has the normal manual sound but it may also be that he has a problem with something like the pilot shaft which goes away when the clutch and therefore the transmission is disengaged.tollboothwilley wrote:Your sound in normal.
Happens with all 6MTs on our cars.
This sound is ubiquitous, Perry. I know you like playing devil's advocate and swooping in with some amazing alternative, but realistically, the chatter sound is well known for just about every 6mt G and Z owner. If you'd like, please search through some of the old threads and you'll see extensive engineering level discussions on the cause, design flaws, and what can aggrivate the situation.pfarmer wrote:
Perry
| Quote, originally posted by Mr1der » |
| go see her, have the most brutal sex ever, then drink most of her milk from the carton and leave. |
Certainly there is an issue with the transmissions, however regardless of make of car transmissions do develop issues based on wear. My 67 Cougar certainly wasn't an Infiniti, however it certainly started to have transmission noise due to pilot shaft bearing wear. I also have had many, many manuals that had clutch throw out bearings that would rattle as well.Sentientbydesign wrote:
Could be since no one here as the ability to actually personally hear the car. It could also be the pilot shaft bearing, or like the experts here think, the normal manual transmission sound.SVTCOBRA wrote:so this isn't the throw out bearing????? Mine rattled for years in the used cobra I bought. Had 60K miles on it. Was still rattling at 84K when I sold it.
clutch was still strong, so I never tore into it.
And you may be correct in your online diagnostic routine.Sentientbydesign wrote:Again, I invite you to search through the archived threads for a LONG discussion on this subject. I've spoken to numerous mechanics about this situation as well as a plethora of 6mt owners on the forums and it has always been the same issue.
In some cases, the sound develops even before the OEM Dual Mass Flywheel is worn out.
Not too terribly unusual for the throw out bearing to rattle and not too terribly unusual for you to never have to replace it.SVTCOBRA wrote:so this isn't the throw out bearing????? Mine rattled for years in the used cobra I bought. Had 60K miles on it. Was still rattling at 84K when I sold it.
You may be 100% sure it is not the throwout bearing on your car but you would have a hard time being 100% sure it is not something other than normal noise on otaku1010's car unless you happen to be Merlin.joe603 wrote:I'm 99% sure it's NOT the throw out bearing...I've had my service department replace it numerous times before it was deemed "thats just how the car sounds".
Also let me say that just because you take it to a dealer for work, doesn't mean they know everything...When I had my aftermarket flywheel/clutch installed during a transmission replacement, they ordered another transmission after putting the car together and it made the rattle. After the second one did the same thing, they said that's just how the car sounds...
After that, I called the performance shop where I purchased the lightweight flywheel/clutch to see if they had heard of the problem. They said the reason for the sound is that the 6MT has beefy gears and a thin trans case, which was a trade-off to save weight. The dual-mass flywheel is used to help smooth out the engine pulses and thus help reduce the transmission gear chatter.
If you think about it, when you engage the clutch, you disconnect the link from your engine to your transmission. In neutral, nothing is spinning until the clutch is disengaged (up). This spinning of the gears.
