radio issue
chanty
Car: 2003 Infiniti G35 (sedan)
I previously had my husband install my Bose radion in my 2003 Infiniti G35 (sedan). A few days later I noticed that all of my speakers werent playing. Currently the only speaker playing is the rear driver's side door. At times the front passenger side door will popon & off. If you push the radio into the dash it will also pop on bt it rarely stays on. Is there something loose.
telcoman
I feel sorry for your husband.
I'll be he's never going to hear the end of this :chuckle:
Telcoman
AppleBonker
So your car started without a Bose radio, and you tried to swap over to one? Did it work at any point? Typically the radio install is far more complicated when upgrading to the Bose system than people would think. It requires running new cable throughout the car, installing a new amp and replacing speakers (beyond just changing out the head unit). Any more information you can give would be helpful.
chanty
It's the original Bose radio that came with the car. It was taken out and shipped to repair the circuit board. when he put it back in it did have full function but a few days later the speakers started to go in & out. Now the only speaker that plays without a problem is the rear driver side door. The front door comes on but goes off & on. When you push the radio into the console the speakers pops on. Is there a loose wire or two. The rear speakers are not playing at all. All speakers did plat when he initially re-installed it.
