TorqueSplit »
https://forums.nicoclub.com/torquesplit-u163851.html
Mon Jul 23, 2012 9:54 am
***UPDATE*** Okay this might be terribly obvious to some of you, but in case it isn't. The left front and right front sensors appear to be exactly the same! So, to test the supected bad RIGHT FRONT sensor, I simpy rigged up some leads to go from the Right side wiring harness to the left side sensor. I used small paper clips to plug into the sensor plug, and 4 insulated small alligator clips, two to clip onto the harness plug leads (a tight sqeeze), and the remaining two to grab onto my paper clip leads, that, and about 3 feet of wire to connect the two alligator clip ends. I unlugged both sensors at the wiring harness and used my leads instead. If the sensor was definitely dead, then I expected my ATTESA ECU to change from a "1" code, to a "2" code - and it did. So I'm certain that the problem is the sensor using this methodology. Make sense?
