tyndago »
https://forums.nicoclub.com/tyndago-u6108.html
Mon May 28, 2012 5:33 pm
There is no fuel priming, but you can hear the primer working?
There is only a fuel pump. The fuel pump provides pressure to the rail. What happens if you hotwire the pump?
There is a FPCM that sometimes dies, but you shouldnt' hear the fuel pump.
Did you test the fuel pump? Check the lines? If you hook them up reverse, nothings going to work.
