i wanaskyline wrote:So I just got mine a couple of weeks ago, and I was hoping to get some advice/info on what I should use for upkeep of the RB26 and the Car from folks that have these cars. I did do some searching on this site and others and found lots of different answers. So what kind of oil/oil filter do ya'll use? What octane does it run best on (im guessing the highest avalible), and which will be just good enough since gas is getting expensive. Should I use any engine oil additives?(I dont think I am going to but your suggestions are welcome) What transmission fluid should I use. Spark plug suggestions and anyother car maintenace items or fluids you might use. Thanks in advance.
O yeah, I went and got a 15W-50 full synthetic oil b/c I read that on many sites, and I also got a Drive Joy V9111-0102 oil filter.
I used mobile1 in my old R32 wtih a mobile filter. I doubt you'll be tracking your car so any good brand of oil is fine. Aomori Prefecture gets cold so, if you plan on driving during the winter, get a supporting viscosity. Go to a local Yellow Hat and/or AutoBacs and see what they recommend.
As far as Octane, I used nothing but Shell V-power (highest octane). I recommend you use Shell or Eneos don't fill you precious GTR with the cheap stuff (esp base gasoline). Moreover, your car is old and who knows what condition it's in. The Shell gas has detergents that can help clean your injectors and/or fuel system.
Don't use engine additives, crazy.
I used OEM fluid in the trans. Is there a reason you should use otherwise? Are you tracking your GTR regularly? OEM can be expensive but it was designed for the GTR trans and it's probably your safest bet.
As far as maintanence, make sure your turbos are still good and dont need repair or rebuilds. This is something you won't be able to do yourself so get your GTR buddies to work with you. Make give you their opinion on your engine condition as much as possible. Check your PS fluid - it'll probably need to be changed. Your Diff fluids will proably need to be changed.
IMO, getting Nissan to check the vehicle is best. When I get another R32 I'm immediately taking it to Nissan so they can do a multi-point inspection. Its going to be expensive but I'll need them to identify any possible problems I may have. I'm paying them for peace of mind.
themadscientist wrote:
If you want to leave the engine in you may be able to support it across the strut towers and drop the cross member to allow you to drop the oil pan. I would tap the drain plug hole for a larger drain plug after that. You can't be sure there aren't shavings in the pan with it bolted to the motor.
Whoa, whoa. This guy doesn't seem to know much about cars. I can tell he's willing to learn but a problem such as oil pans should be handled but professionals.
