R32 diff in s14
TeamTorqueJuggernaut
Car: 90 Nissan 240sx
Ok Ive been searching and still havent found a real answer on if a r32 diff will fit in a s14. Right now I have a r32 diff in my s13 and Im trying to see if it will fit in my s14.
E7-S14
Car: ess 14 foo!
a bit more searching would have told you yes.
use s13 bolts(there shorter) and swap rear case covers.
thats it.if your axles arnt 6boltbuy 5bolt axles for the s14.
there you go.. answered.
blacktop20
sweet.....thanks man
blacktop20
i posted the same quetion a few days ago.
LOVERboy
Car: 1997 240sx se KAT
E7-S14 wrote:if your axles arnt 6boltbuy 5bolt axles for the s14.
sooo 6bolt or 5bolt axle?
E7-S14
Car: ess 14 foo!
depends on what the diff has.
im using an s13 diff in my car which has 5bolt output shafts.i had to swap my 6bolt axles with 5bolt ones for it to work
and be sure you get your axles out of a NISSAN 240sx! as there is no chance of having one too long/too short/ wrong sizes
Ive got the five bolt axels that came with the diff. I know another thing I have to do is change the cover on the back with the s14 cover right?
