joe603 »
https://forums.nicoclub.com/joe603-u34652.html
Wed Aug 15, 2012 7:59 am
No, the warranty will be fine. The way it works is that if the aftermarket part specifically caused the issue, then the warranty would not be covered for that component. For example, lets say you replace your suspension with aftermarket and after a while it breaks. You can't use the warranty to fix it. Another example is if you install a supercharger and blow your engine...the warranty will not cover a replacement...but if your window motor dies, that is covered.
So if you install the R2C intake and the fan blade comes off damaging it, it will not be covered. But if your timing chain goes and destroys your engine, that would be covered.
Hope this helps!
