dbaxRonin »
https://forums.nicoclub.com/dbaxronin-u181868.html
Thu Apr 03, 2014 5:40 am
So last night I finally got a chance to install the new R2C CAI kit I ordered from TunerzStore (Who was AWESOME to work with, btw). Although the assembly of the parts went without a hitch, the install presented one issue when it came to the crankcase hoses.
In an effort to get the crankcase hoses to mount to the pipe on the new tubes properly, I tried all sorts of arrangements and configurations between reversing the existing hoses, using the new one supplied with the kit, etc etc. No matter what I did, I ended up with a bit of a pinch in the hose right were it comes off the new pipe. Its not a complete pinch in that it would completely block off any air-flow, but I imagine it is enough to restrict it somewhat.
I had to actually use the supplied hose on the drivers side...the factory hose wasn't even close to lining up. I had to cut about 3" off of it to fit. I ended up just reversing the passenger side factory hose and that lined up well enough, though it was a bit of a struggle to fit the clamp on.
Anyway, I guess I am just curious if this pinch will present any long-term issues. To this point, everything seems fine when I drive it, but I don't know if this is something I should in some way be concerned about. What exactly do those crankcase hoses do anyway...just provide some ventilation out of the crankcase?
I appreciate any feedback. Thanks.
