180fan wrote:UV detector. You put a small amount of gaseous dye into your system, and put the light to it. If you see a neon colored gas being emitted from your system, you've found your leak. I think you can find stuff like that in your AC Coolant and recharge section at an auto parts store.
Actually it's the oil that leaks out with the freon that will be glowing under the UV. There usually isn't enough gas to be visible (better not be). But without the UV, you can look for grimy areas near the AC line junctions. Oil traps dirt. It's hard to find stuff compatible with R-12 systems since they're far less common and since you need to be EPA-certified to perform any R-12 repairs.
Get a multimeter and a manual and check things one at a time. Start at the compressor and work your way up. See if there's voltage to the compressor with the AC switch on. Then check the pressure switches for continuity from the connectors. If there's a temp switch, check it too. Then check the relay to make sure it's working fine by supplying a voltage to the right terminals and checking continuity across the other 2 before and after. If everything checks out fine, and the compressor isn't engaging, then you probably have a bad compressor.
