this motor I have upgraded the rod bolts and head studs with ARP after losing a motor last January to a conrod bolt
There are guys on ls1tech.com running 600hp+ (to the wheels on bone stock motors). So don't look at old info here as the benchmark. A LOT of it is in the tune. Also many of them are running 100% E85 on inferior motors (inferior to our VH at least). To get to 600 at the wheels, the smallish (for a V8) VH45 will definitely need your rod bolts and head studs...you will be upping the boost quite a bit to get there, but with a good tune I think these motors can thrive, not just survive.
This guy for example, is running a turbo'd E85 6.0 chevy V8 (the LQ4) in an old volvo...and runs a 10.7! and close to 600 at the wheels.
http://ls1tech.com/forums/forced-induct ... 8-8-a.html
Personally I plan to turbo my Q, just a few more months on the grad student loans
paying 2k+ a month right now to pay them off fast, fun times!
I plan to run the following in my beautiful '92, currently less than 90k on the clock
aftermarket E85 compatible fuel pump (that can handle 600+ whp)
750cc E85 compatible injectors
rear mounted Chinese ebay GT45 - fed by custom exhaust and custom quick spool valve (google it - basically a wastegate on the feed side of the turbo that opens when you start to get into boost... gives you even quicker response time and Zero lag.
aftermarket radiator
FMIC - probably still run an intercooler even with E85, here in hot azz central TX. That volvo for example above is non intercooled - advantage of E85 is it cuts down on your temps, and reduces the chances of detonation
Shane Christopher tune, but eventual Megasquirt or Nistune?
beefier engine mounts
the weak link IMO is the transmission - autos are usually the weak link in a build seeking 600 to the wheels. Level 10 transmission or not, I'd personally go built Z32 5 speed...but it will be a tiny bit slower drag racing.
I feel like I'm leaving something out, but these are the major points at least
the wheels I'm running now: in 18x9 - the offset is a bit much, they stick out just a bit, but I like 'em too much to change...plus I "should" be able to go with some serious wide tires on these in the rear. The car came with 245's, but I think 275's will fit in the rear.
keep us updated! that and I need to PM you!
