Dynojets are way optimistic. Was hood closed with large 220V ducted box fan cabinet coupled to the front inlets? Floor fans are a joke. Of course under engine tray is mandatory to maximize cooling flow.Q-ZILLA wrote:453/453 on the dyno at Z-Fever in Tampa. Maxed out on stock injectors.
Sorry for the real information.Q-ZILLA wrote:Maxnix, when you own your own shop or get certification, then chime in... You don't know half of what you're talking about and I thought I already asked you to stay off my posts.
Again... STAY OFF MY POSTS.
I can show you how much mine my rear mount standalone oil system either smokes or consumes oil (depending on the psi and flow I set into the turbo)You knuckleheads are giving me the Q itch again, dammit!
Any reason you decided to use the pump to push oil through the turbo? In mine I'm using throttled down engine oil pressure to supply the turbo and my scavenge pump pulls it out. Do you have some sort of pressure regulation from over pressurizing the turbo? Is the reservoir below the turbo so it can drain freely into it? Mine ran great like this for years, eventually it's started leaking just because the turbo is due for an overhaul.Brew Q wrote:I can show you how much mine my rear mount standalone oil system either smokes or consumes oil (depending on the psi and flow I set into the turbo)
I'm about to remount the pump down lower than the turbo and that should fix the oiling issues with it. Currently its pushing oil into it, mounted lower it will pull oil out of a catch can under the turbo - should work much better. If all that fails, I'll just tie into the oil cooler on the front of the car and run the turbowerx as a scavenge pump.
I just finished (today) redoing the whole thing. I ran oil lines from the front of the car (T''eed off an oil cooler) to the rear of the car and then out the turbo to oil cooler/pump. The pump then pushes the oil back to the motor, (using the pump as a scavenge pump). I put a smaller restrictor on the turbo (.060).qsiguy wrote:Any reason you decided to use the pump to push oil through the turbo? In mine I'm using throttled down engine oil pressure to supply the turbo and my scavenge pump pulls it out. Do you have some sort of pressure regulation from over pressurizing the turbo? Is the reservoir below the turbo so it can drain freely into it? Mine ran great like this for years, eventually it's started leaking just because the turbo is due for an overhaul.
just running 7 psi right now, at least until I get the kinks ironed out. I suspect I've got a leak near the MAF, may have to install a BOV. Usually it tops around 6 psi with the leak, but I've seen it creep once or twice close to 8 and it was eye opening power to say the least! Meth injection kit and the fuel pressure riser help a lot though - no detonation at all...AFR's look good under boost.Q-ZILLA wrote:Glad you got it going right. How much boost are you currently running?
