I have 18x9 BBS RGR NIB. email me if you are interested.Q-ZILLA wrote: Wheels are on it. I am thinking of going back to BBS RS or LM wheels, trying to get the stock look back. I want to get 18" or 19" staggered.
Always pull the fuel pump fuse on initial first time start up to get the oil in the HLA before firing it up.Q-ZILLA wrote:QZILLA has awakened from a short hibernation…
I have to say, I was pretty nervous to start her up. The valves were ticking, but that went away once the oil started pumping.
Thanks for the input... A day late and a dollar short. I have one or two HLA's that bled out, fixing them today. Wish you'd posted about a week ago...maxnix wrote: Always pull the fuel pump fuse on initial first time start up to get the oil in the HLA before firing it up.
VERY NICE! I know I have a couple spare axle shafts, I can see if the clip is still there...Q-ZILLA wrote:Well, I almost stuck with the plan... A turbo'd Lexus IS I believe, jockeyed behind me on a turn, then jumped on my right side flooring it. I hesitated a second or two, because I only have 435 miles on the build and wanted to get to 500 before I really throttled it. Anyway he ran out of gear too soon, I flipped it into 4th and walked away, god I love my car! The reason I'm not quite sure what it was is because his lights were all I could see, but it looked like an IS. It was pretty damn fast!
I'm assuming with my car running 9:1, instead of 10.2:1, that my 15lbs of boost is now equal to about 10lbs in relation to the old setup. I need to get tuned bigtime!! The car is running better than it has for a while. The engine pulled like a bear, didn't drop into 3rd on me at high rpm, like it sometimes did before. The difference in power is AWESOME!
Wes, I have a rear diff issue, side gear munching my shaft. That sounds interesting, but it's not. I have another diff, but I'm all out of shafts. Can you spare a drivers side shaft? I'd be happy to Paypal you some money for it and for shipping.elwesso wrote:NICE! I know I have a couple spare axle shafts, I can see if the clip is still there...
Thought I'd add a pic for you to contemplate... Both looked new when installed.Q-ZILLA wrote:Wes, I have a rear diff issue, side gear munching my shaft. That sounds interesting, but it's not. I have another diff, but I'm all out of shafts. Can you spare a drivers side shaft? I'd be happy to Paypal you some money for it and for shipping.elwesso wrote:NICE! I know I have a couple spare axle shafts, I can see if the clip is still there...
I'm taking the carrier out tomorrow and replacing the diff. I've never heard of one of these failing, but It munched 2 shafts already.
Yeah, I've been doing a little reading... It's not cut and dry, under pressure with a precise volume air bubble. Not worth the aggravation or the potential failure. I think I'll have to add a better diff to my wish list.elwesso wrote:I don't think you can do that on a Nissan VLSD... That would be great, because really the only reason the VLSD stops working is because the fluid breaks down, but I know most other Nissan people that run high HP VLSD just get a different unit once it's fried...
