qx4dude wrote:It is a 2002.
How often does the tranny oil, transfercase oil, and the diff oil need to be replaced? I have had my truck for 6 months but i have no clue when they need doing. Thanks!
At 152k, its about time to replace the tranny fluid and also the filter.
You have already done the oil and plugs. You could do the following too.
1) Transmission - drain and pour. Should take about 5.5 qts of fluid if you drop the pan. Change the filter as well. You'd need a 75winter90. Id do it every 25k miles. Or subsequently just drain around 2 qts from the plug and pour every 7k miles perhaps.
2) Differential - Drain and pour. Would take 3 qts approx. 80w90 is the spec although that'd be a little harder to find. Especially with synthetic. The front differential should take less fluid although I am not sure as mines a 2WD. 75w90 royal purple is often recommended here and will be what Id get the next change. Dont need to do this very often for strictly on road driving.
3) Transfer case - ATF. Should take around 3 qts IIRC.
4) Fuel filter - once a year.5) Air filter - its very cheap and a takes just a minute. So just about as often as you feel you could do with a new one. 6) PCV valve - once every 2-3 years. 7) Throttle body cleanup. every other year.8) MAF sensor cleanup. "8) Coolant flush. every other year. 9) Tires - rotation. Balancing and alignment if required. once a year. 10) Top off fluids. as applicable. 11) Propeller shaft grease/lube. 12) ignition coils as well.
