QX-4 Bushing above brake pedal
miami3
Car: 1998 Infini i30
2001 Infiniti QX4
Hi everyone. I have a 2001 QX-4 and noticed that the tail lights were staying on. After investigating I saw that there are two switches just above the brake pedal. The switch is activated on/off when the brake pedal is pressed. One switch deactivates the cruise control and the other activates the brake lights.
The bushing that activates the switch has deteriorated. After trying to temporarily glue the bushing back in place it didn't hold. Later I cut a golf tee (don't laugh) so that it fit the same way the bushing did.
Does ANYONE have a clue a) where to find a replacement, b) what that piece is called and c) tips on how to replace it? I admire mechanics because I can either fit my hand at the spot OR see it--not both!
Thanks in advance!
atraudes
Car: 2001.5 Infiniti QX4 4WD
If it's stupid and it works, it's not stupid ;)
This parts view should help you find the part and order a replacement. Sorry, no tips on getting the new one in :frown:
