monte0704 »
https://forums.nicoclub.com/monte0704-u256021.html
Tue Sep 08, 2015 3:38 pm
If it counts for anything, I just bought an OEM harness off eBay for $110 with shipping. Part Number 24079-05U00
If you are looking at the plug, with the coil pack facing downward, like it would be in your motor, you are looking for 0.6-0.9 Ohms between the leftmost and center pins. Anything outside that, and you have probably found your issue.
For what it is worth, next time I do coil packs or this harness fries, I'm moving to the R34 coil packs, using the RightDriveParts kit that is linked above.
