questions regarding a gas pedal vibration issue
Postby mslugx » Fri Jun 19, 2009 9:18 am
Hi everybody. I just noticed a problem with my 04 G35 sedan. The issue is when i am going on a constant speed, and i am lightly touching the gas, the pedal attends to vibrate or rattle, but that only happens to the pedal. If i step on the gas pedal deeper the vibration is gone, everything else is fine. I am just wondering what's wrong with this. could it be the spark plugs or other compartments? Thank you very much and have a nice day.
mslugx
Car: 2004 G35 Sedan
Re: questions regarding a gas pedal vibration issue (mslugx)
Postby Poyzinous » Fri Jun 19, 2009 10:52 am
Its probably just the car begging to be driven with all 280 horsepower.
Its also a possibility that there are just chassis vibrations and things. I usually feel a little bit of vibrations/physical resonance but nothing to alarm me. Check to make sure the pedal is firmly bolted to the firewall. Its only held on by 2 nuts and studs.
Click here for an oil change how-to
Win free stuff for your car! Click here!
Xbox gamer tag: Poyzinous
Poyzinous
Car: 2004 G35x Premium 1976 Classic Red 36 inch #18 Radio Flyer Wagon...
Postby SVTCOBRA » Sun Jun 21, 2009 4:27 am
Every so often I feel a vibration in the pedal of my 04 coupe.
Never heard a rattle tho.
If you push it to the firewall, it goes away!
08 G35X sedan, 04 G35 coupe, 00 MAX SE , 05 Ford Focus ZX4 SES << (93 Octane, Mobil 1 Syn , Zaino) (Z Tubes) (SBD Grounding Wires) >>
SVTCOBRA
Car: 08 G35X 04 G35 Coupe
Postby joe603 » Mon Jun 22, 2009 5:10 am
These cars are a drive by wire design...so you're probably feeling normal vibrations.
Check your pedal with the car off. Does it have any play? There may be lose screw/bolt that holds it on.
joe603
Car: 09 G37S sedan
Postby mslugx » Tue Jun 23, 2009 7:24 am
Thanks for the reply everybody. If you guys say so, then I guess it's ok. I check the pedal and all the bots and screws are in place. Thanks for the help, please keep me updated if you guys find anything.
mslugx
Car: 2004 G35 Sedan
Return to G35 and G37 Engine, Drivetrain & Tuning
