Ilya »
https://forums.nicoclub.com/ilya-u159401.html
Mon Oct 27, 2014 11:03 am
I have BC's on a 2007 M35x. The install was easy, however, I had trouble adjusting them (I don't understand the concept of the collars/pre-load too well evidently), so I had a shop do that part. They were good for a while but have become noisy. In the sense that being lowered has started to blow my front stabilizer links 5k-10k after replacing resulting in a clunking noise. Also, at full left or right lock, there is a pop which I believe is known as spring binding as a result to an incorrect preload (which was fine - nothing changed - noise just appeared). I've gotten alignments, had the suspension re-set, still happens.
Knowing all that above, I probably would have gone with a traditional static strut/spring combo...I'm just dealing with it now.
As for ride comfort, it rides like stock but handles far better in the corners.
