nlzmo400r wrote:i didnt think t6 was an actual turbo, but i was referring to a single t66, ive seen it done before, but from waht u just told me im assuming a big single is easier on a straigh motor rather than a V?
nlzmo400r wrote:but it can be done? is that why all of the turbo set ups ive seen for the 35oZ have been twins? i always wondered why not just run a seemingly less complex single turbo, with a slightly larger turbo
nlzmo400r wrote:it just seems so wierd how twins would be easier than a single turbo, and u almost never see high hp supras with twins anymore, all of em have big t66,t78,t88 and whatnot for top end, and why is a straight 6 THAT much easier to do a single on? i know it IS easier, but do the cylinder placement make it that easy?
nlzmo400r wrote:i made out your diagrams fine EZ, thanks for all the clarification, but i dont understand why a 'theoretically twin turbo'd' 35oZ would have to be set up any differently than a 3oozx twin turbo, and und3rprshur, a larger single turbo will almost always give u more power than two smaller turbo's, the twins will spool faster most of the time, but all of these hwy supras run large turbo's for top end, i havent seen twin turbo'd supras run over 55ohp or so, but ive seen single turbo'd supras easily hit 8oo+whp
from the diagram u showed me, the z32 tt and z33 tt are differnt, why are they different if they are both v-blocks, or also, why would a single set up be different between them as they are teh same type of block?EZcheese15 wrote:I don't understand your question. Do you mean why a single turbo 350Z will have to be set up differently than a single turbo Z32? The single turbo Z33 and single turbo Z32 are obviously different set ups.
nlzmo400r wrote:from the diagram u showed me, the z32 tt and z33 tt are differnt, why are they different if they are both v-blocks, or also, why would a single set up be different between them as they are teh same type of block?
and im guessign the z32 uses twin throttle bodies only because its a TT from the factory, while the z33 isnt?, and if thats correct, what about TT'ing a non turbo z32, would that have a single throttle body like the z33 , except only at the front?, and one more question, why have the throttle body at the rear of the engine? as opposed to the front?EZcheese15 wrote:Because the Z32 uses twin throttle bodies that are located at the front of the engine. The Z33 uses a single throttle body located at the rear of the engine.
nlzmo400r wrote:and im guessign the z32 uses twin throttle bodies only because its a TT from the factory, while the z33 isnt?, and if thats correct, what about TT'ing a non turbo z32, would that have a single throttle body like the z33 , except only at the front?, and one more question, why have the throttle body at the rear of the engine? as opposed to the front?
very good possibility about the resonators, thanks for all of the answers torry, i know i asked a lot of questions, but i really appreciate your help, how'd u get so damn intelligent? is it just experience with these cars, or did u go to school for themor something?EZcheese15 wrote:The NA Z32 also has twin throttle bodies. It's just the design of the intake plenum. Has nothing to do with being turbo.
The throttle body of the Z33 is located in the rear of the engine just because it's the design of the intake plenum as well. If you want to get down and dirty, they probably designed it that way so that they could lengthen the intake tract (by having to route it all the way to the back of the engine bay) so that they could add more air box resonators in the system to make the car quieter.
nlzmo400r wrote:well then even stil, why have 2 throttle bodies if they're not 'needed', assuming the only reason for the 2nd throttle body is because of hte turbo's
