crazyboy3012 »
https://forums.nicoclub.com/crazyboy3012-u72903.html
Sat Apr 19, 2014 6:06 am
Hello,
My local mechanic while inspecting my car mentioned that the front left wheel bearing needs replacement.
The question is, how do you know the bearing has worn out...I drive my G everyday and I have not found a noticeable difference. I was also told that the bushing on the left and right side needs replacement. It was recommended to change the whole front left and right lower control arm which is expensive.
Is it possible to replace just the bushing?
If i replace the front wheel bearing, should i replace the bearing alone or a bearing-hub assembly? Also, is it ok to replace just the side that is worn out or should i replace both the front left and right side?
Thanks a ton !!
