McSteve wrote:i think aftermarket rims will most likely improve your ride's quality and change the look completely. as i read somwhere on this forum. Shoes make the man, rims make the car. I got a really good deal on mine. You can see em in the sig
Actually ride quality depends on the sidewall size. If you go with bigger rims youll have a harsher ride due to the smaller side wall. Since the side wall is smaller the tire has less room to "flex" hence the roguher ride. Rims and tires can be a suspension upgrade since they are the only thing that touches the ground. I think it was gripmotorsports.com, they have the tokico blues for about 70 each. Dont go oem...the stealership will rip you a new one.
