Thanks everyone
Thanks!Hijacker wrote:The ABS driveshaft is an inch shorter due to the differential being different between ABS and non-ABS cars. Jack the rear up, look at the diff and if you see a speed sensor on the front of the housing, the diff was used in an ABS system. If there's no sensor there, the diff is from a non-ABS system. Order your driveshaft accordingly.
