its no bolt on.. for the 25 it requires drilling out the lower hole, grinding down a little bit of the block, and chopping the **** out of and redrilling the stock bracket.. this is to retain the stock 25 belt.. might get away with a slightly longer one... then you will have bracket issues..StricNyne wrote:i know the quest alternator is an upgrade for the rb but i wasnt sure what year to use could someone let me know thnx in advance
Did you even bother to read all through this thread?? Scroll up and look at CarlH's reply he already said which alternator to use... Unless you had a more specific question but "what alternator" was answered twice in here already.drivnovrdaedge wrote:NEEEEEEEEEEED HELPPPPPPPPPPPPP ASAP
WAHT ALTERNATOR FITS ON AN RB20DET BOLT ON ?
STUCK IN PORTLAND .. AND I LIVE IN TACOMA WASHINGTON
NEEEEEEEEEEEEEED HELLLLLPPPPPP
WHICH ALTERNATOR CAN BE USED AS AN ALTERNATOR FOR AN RB20DET?
Oh. Well, I hadn't seen one in person. I was just going off the pics in this thread. I dunno, just a shot in the dark.Carl H wrote:the quest alternator is effin huge...i doubt a cover swap would work.
