Q45 transmission swap??
Mikey_ZX
Car: 91 Infiniti Q45 1st Gear Start
94 Nissan 300zx N/A
2008 Chevy Aveo 5
2013 Toyota Venza Limited AWD
Hello again everyone,
Does anyone know if I can use a transmission from a Nissan 300zx Twin turbo inside my Q45. I need confirmation because I think I have read that the Q45 and the twin turbo z have plenty of parts that are interchangeable. Was thinking about ordering a rebuilt from Z1 motorsports if the swap is feasible. Any input would be greatly appreciated.
lino
Car: 1991 Q45a Fed-Spec, IQP/White, Texasoil 9 Accumulator Recharge, '93 TCU 1st Gear Start, JWFSB, B&M 70268 Transmission Cooler, BBS Forged Wheels, DRLs, Silverstars, Tint, Very Well Serviced.
Why do you want to do that? :confused:
The 300ZX twin turbo and the Q45 automatic transmissions are both an RE4R03A.
The part numbers are different though. Here are all the part numbers I could find. Hope this helps you:
Q45 Part numbers:
TRANSMISSION ASSY - AUTOMATIC
Part Number: 31020-51X09 (supersedes to 31020-51X65)
Prod.M/Y:0889-0790
Part Number: 31020-51X15 (supersedes to 31020-51X65)
Prod.M/Y:0790-0491
Part Number: 31020-51X21 (supersedes to 31020-51X65)
Prod.M/Y:0491-0292
Part Number: 31020-51X63 (supersedes to 31020-51X79)
Prod.M/Y:0792-0795
Part Number: 31020-51X65 (supersedes to 3102M-51X65)
Prod.M/Y:0292-0792
Part Number: [b31020-52X09[/b]
Prod.M/Y:0795-
Z32 Twin Turbo Part numbers:
Part Number: 31020-51X08 (supersedes to 31020-51X70)
Prod.M/Y:0790-0393
Prod.M/Y:0789-0790
Part Number: 31020-51X70
Prod.M/Y:0993-0795
Part Number: 31020-51X78
Prod.M/Y:0393-0993
Part Number: 31020-52X08
Prod.M/Y:0795-
You can check the prices here:
http://www.infinitipartsusa.com/partloc ... &siteid=55
Mikey_ZX
94 Nissan 300zx N/A
2008 Chevy Aveo 5
Thank you for helping me out, my transmission hasn't died yet, but just trying to get some information for the future. Thanks again.
lino
No problem. Is there anything wrong with your transmission right now?
Any symptoms indicating it's getting tired or are you simply gathering info to be prepared in case one day you might have to replace it?
Do you think their might be an advantage using the 300ZX transmission?
Mikey_ZX
94 Nissan 300zx N/A
2008 Chevy Aveo 5
There is some grinding going on when shifting from 2nd to third going up hills and I'm basically looking for a place that can provide me with a quality rebuilt transmission.
qship96
Car: 1996 Infiniti Q45
In my 33 years of driving, never have I heard of an automatic transmission "grinding" between gear shifts.....now a manual transmission, yea.
elwesso
Car: 94 Infiniti Q45t 5 spd
2007 BMW M Coupe
2007 Infiniti G35 S 6MT
I think you might be able to get it to work, the bellhousing will bolt on.. So im guessing that it should be OK, you might have to mix and match things like TC's...
I would reckon that you might be better off just not hassling with it and either getting used Q45 trans or rebuilt from nissan.
