Without a doubt in the hot south, add an ATF cooler and M1 if your car is a keeper.bullittandy wrote:What type of conventional trans fluid does a 97 Q45 take? I've read about Mobil 1 but would like another option, other than the dealer.
I AGREE totally. More important to change fluid often then to buy good fluid and think you can go longer!texasoil wrote:Mobil1 is highly oversold. Modern DEXRON III flu9ids are extremely heat stable compared to earlier fluids. There IS a different at real LOW temperatures, and if you live/drive where degrees C & F are the same (-40), a true synthetic ATF -like Mobil 1 or AMSOIL is preferable.
The additive package is essentially identical in all the Dexron -III fluids. Valvoline, Chevron, Texaco, Exxon, are ALL excellent ATF's. I always recomend and use a pint of LUBEGUARD Red in an ATF change. Lubeguard is THE BEST clutch lubricant and ensures smooth clutch lock-up, reducing shock and wear on expensive metal parts
TexasOil from a previous Post (Read'Em!):qship96 wrote:how about adding lubegard BLACK to the tranny fluid instead of RED? from what I gather the black version is the red formula with friction modifiers added to closer simulate the Nissanmatic D fluid- use half of the 11 dollar bottle,save the rest for your next flush.
Look at LEVEL 10 transmission build-up! All they do is modify pressure aplications to each individual clutch pack (brake band) by mans of modified valves/solenoids. Also, you can increase line pressure with different pump (care should be taken) or seals will leak. I work with a guy how knows trannies like his own hand (about 30 years of trannies build-up) he is 63 y.o! I suck information from him every time I get a chance!He is an expert in A4OD (FORD) TH350/400/700R4(GM) and TorqueFlight(CHRY) When varnish is formed on clutches/bands there is nothing you can do, simply wait till it silky smooth (slipping) and do a rebuild Valves/solenoids can be cleaned/replaced as well as springs. His oppinion on different additives was simply waste of money Cleaners/conditioners might help rejuvenate slightly tired transmission otherwise it's just senseless. I use regular dexron III for high milage transmission (added some conditioners and friction modifiers) and check fluid every time I open hood of my car (every week)!Smell is important because color is not an sign of bad fluid. New Mercom is very dark in color (looks burnt). ATF+4 stinks like you want to puke ALWAYS CHECK ATF - SMELL ITtexasoil wrote:I don't claim to be the know-all in lube s and additives, but I have been involved at a technical level for over 25 years and did serve a significant stint in lubes formulation, manufacturing, and field tech support with the company that at the time made more lubes than anyone else.
Regarding Lubeguard. (No comment on Nissan D fluid since I am ignorant of the specific characteristics) I AM knowledgeable on DEXRON (all previous and present versions) and the 'type F' fluids.
Q45's through version III for certain were designed for the friction characteristics of DEXRON. This fluid had friction modifiers that shallow the slope of the torque vs slip curve as the clutches approach 'lock-up'. AND these fluids are suitable for those cars that ALLOW continuous slip of the 'lock-up' torque convertor to smooth things out.
Some transmissons are designed for different fluids, ones that have either no drop in torque transfer as slip goes to zero, or even fluids that have HIGHER torque transmission ability as slip drops to zero. This characteristic is called HIGH STATIC FRICTION. Dexron fluids have HIGH DYNAMIC FRICTION.
If youput a 'high static' fluid in a transmission designed for 'high dynamic' fluid, you will significantly increase clutch lock-up shock--even to the point of shearing the metal driving lugs on the clutch plates. You may even feel a 'firmer shift', but that is easily confused and misnamed. You can also get a 'firmer [faster] shift with higher viscosity fluid or increased oil pressure in the transmission operating circuit. 'Firmer shift' and 'clutch lock-up shock' are different processes and not necessarily coincident. You can have 'soft shifts' caused by worn clutches, leaking clutch pack seals, low oil pressure, and STILL have 'lock-up shock.' You can have fast, firm shifts and still have smooth , no jerk clutch lock-up.
I recomend AGAINST adding Lubegard BLACK to Q45 transmissions in an attempt to get 'firmer shifts'. All you are doing is increasing the momentary torque loading( lock-up shock) on the metal parts in the tranny and can brak some real expensive parts. This transmission IS NOT designed for harsh shifts and WILL break.
IF your Q45 tranny has slow, lazy shifts at moderate and more throttle openings, slips on shifting (engine speeds up), then either your throttle position switch is misadjusted, the transmission is worn and leaking internally, the oil filter is plugged, the fluid burned (worn-out), the clutch linings coated with varnish (from infrequent oil changes) or the valve body is malfunctioning for some reason.
Change the fluid. Add one pint of Berrymans Transmission cleaner and seal conditioner--run it easy for a week, re-drain and refill with DEXRON III --not synthetic--most DEXRON III fluids already have as much as 50% 'synthetic' base oil in them to meet the very low temperature viscosity requirements. What you are trying to do is clean off the clutches, clean out the valve body, and renew the friction modifier additive package. IF the shifts are not velvety smooth on lock-up, add one pint of LUBEGUARD RED. Do not confuse 'smooth lock-up' with 'firm shifts'. DO NOT ADD LUBEGUARD BLACK trying to get 'firm shifts'. To get 'firmer shifts' you will need to increase the transmission 'line pressure'. There are after-market spring/parts kits to do this. Use at your own risk. You DO NOT want to create harsh clutch lock-up under any condition--the metal parts will not survive.
