300zex »
https://forums.nicoclub.com/300zex-u240618.html
Sun Aug 24, 2014 5:17 pm
Thanks, but I already know that the vg can achieve that with bolts on, matter of fact my car is set up for more than that. I bought the car with JWT 600 sports turbos, 555 injectors, dual JWT pops , stillen intercoolers, apexi boost controller, JWT 400 cams, JWT tuned ecu, 3inch test pipes and bb exhaust, among other minor mods, but the car came with a rod knock. Rebuilding the engine to a point where I don't go backwards would at least require an ipp stage 2, and that costs a lot. Same as you, I value reliability. I couldn't agree more with your points but I'm not really trying to get a monster in the streets, I'm just trying to figure out the numbers for the vh without going fi, neither compromising reliability. I've read they are good to 600hp, some people say more, but i wouldn't push that far. Anyways ls3 drive with more than 500hp daily so is not like 500 hp daily is a crime, although I do acknowledge the problems that can come with it. Last time I checked John's vh was around 460whp with itbs and no tuning, is not that I'm trying to build the best vh out there, just curious since there is not too much info available, like the z32 stages lists. Also I know aftermarket parts are hard to come by but you can find them. I've already found cams, bearings and springs. My thought was to refresh the engine, all new seals, replace springs, bearings, get some cams, 555 injectors injectors, headers and tune it. I have a hard time believing that with that 400hp cannot be reached. But again I'm just asking for people that had already gone the na way with their vhs since the info is so scarce.
