Q45 R230??
amreboot
Car: 1989 300zx turbo
Hey all
I have been searching and what not for info on the Q45 rear end...
Some places I have read said that some Q45s have the R230.
Other places I have read said that its a R200 with 6bolt flanges like the z32tt r230 but otherwise not a complete R230.
What is the deal or truth to this?
Also, does anyone have the full dimensions of the q45 subframe? Ear to ear mounting points?
elwesso
Car: 94 Infiniti Q45t 5 spd
2007 BMW M Coupe
2007 Infiniti G35 S 6MT
The Q45 has a R200 diff. The 200 just means it's a 200mm ring gear. It does indeed have the 6 equally spaced flanges.
They typically refer to the Q diff as the R200 "short nose", however comparing them side by side they're very similar to the Z32 twin turbo diff, despite having the smaller ring gear.
amreboot
So just to confirm, the following link is incorrect?
http://www.ziptied.com/forums/index.php ... 14.45;wap2
elwesso
2007 BMW M Coupe
If you're saying in regards to the later Q's have R230's, then yes that's incorrect. You can look in the FSM at www.infinitiservicemanual.com for yourself, but you'll see that at least all 97-01 got the R200V. In 97-01, they used the 5-bolt flanges (basically the same as the Z32 n/a) with 3.69 ratio...
