MinisterofDOOM »
https://forums.nicoclub.com/ministerofdoom-u16506.html
Wed Sep 24, 2008 4:51 pm
I don't imagine you'd have any major clearance issues with the VH itself...the Max engine bay is nice and wide. The VH45 is a tall motor, though, especially when you take the intake plenum into account. Z32 guys with VHs in their cars have to modify their hoods.
As for transmissions, the VH has a unique bolt pattern (not shared with any VG). If you want to stock auto, you'll be fine for bolt-in. Otherwise there are folks who make adapter plates to run Z32 5 speeds (or you could possibly have one made to work with a Z33 6 speed).
As for converting to RWD, there are the major hurdles that come to mind:Trans bellhousing fittment. Clearance for the Q45's bellhousing makes an obvious intrusion into the Q's much wider interior. You'd have to modify the firewall and footwells to fit the trans. And since there are a lot of electronics (ECU and TCU among others) stored where the bellhousing needs to go, you'll have to relocate all of that.
Rear axle: The Maxima has it's fuel tank under the rear seat. RIGHT where the rear diff and axles need to go. You'll need to switch to a fuel cell in the trunk or try and design a tank to go vertically behind the rear seat like in the Q. You also have to find a way to make a RWD IRS setup work with the 4th gen.
Another think to point out between the two designs is that the Q45's floorpan is designed to leave clearance for things like exhaust which can't run through the center tunnel thanks to the driveshaft. If you look closely at the Q floorpan, it dips down for actual footwells, and is raised around them. Even so, with my lowered Q, the catalytic converters are easily the lowest point on the car. On the Max, the exhaust will be hanging down pretty low.
