PCV Valve for the 3.3L in 2000 QX4
Mikey178
Car: 2000 Infiniti QX4
Just wondering if anyone knows where the PVC valve is located in the 2000 QX4. I can't seem to find this. I bought a new one to replace but can't seem to find the location.
Anyone got any ideas??
Ron Burgundy
Car: 1999.5 Nissan Pathfinder 3.3 LE
Well if its anything like the 2000 3.3L Pathfinder (which I can't guarentee it is, but its worth checking), there are two hoses coming out the engine block on the right side (driver's side) Pull the hose out thats closer to the windsheild (if it helps the area is called the upper intake manifold) Its threaded in that hole where the hose attaches.
I'm doing this tomorrow, i'll take and post pics. Hopefully it'll help.
Mikey178
Thanks, i'll take a look to see if I find it as you've described but some pics would be good.
Ron Burgundy
As requested...
Here is the engine compartment in full. We will be working in the area between the brake fluid resevoir (big round yellow cap) and the engine block (big silver thing in the middle)
Here is a close up on that area. Notice the four hoses in the center with the silver clips? The PCV valve is located inside the on the bottom right
Here is a picture with the hose removed. You can see the PCV slightly.
Close up picture of the PCV. It is quite a tight squeeze to get a ratchet in here so I removed the two hoses above it to make a little more room.
And last but not least - here is the PCV removed and the hole in which it threads into. Shake the valve and listen for a rattle. If it doesn't rattle - replace it!
Hope this helps!
Mikey178
Thanks for that, I was able to change mine after your first description. I did take pictures myself of the location.
Hope this helps someone else as well, Thanks again to Ron for the pictures.
Pathy415
Car: 2002 Pathfinder LE 4WD
Thanks again for the write up. I just did mine and it was a snap.
GRNMACHINE
Car: 1999.5 Pathfinder SE 4x4
Fantastic Write Up and pics-Thanks Mr Burgundy! Major Jealousy with your clean, non rusted CA engine compartment...
And what brand of wires are those, they are Purday!
jojoriley1190
Car: 1997 Nissan pathfinder
What hose is that underneath the air relief valve? It popped off and fell on my header and burned up and I have no idea what hose it is and where it goes. Any ideas?
fueler
Car: 2 Nissan's
2 BMW's
nevermind
rgk
Car: 02 Pathfinder LE 3.5 auto 4x4
GRNMACHINE wrote:And what brand of wires are those, they are Purday!
Look like NGK blues to me.
