Details:Project Kics wheel spacers are high quality spacers from Japan. Wheel studs come pre-pressed so no additional work is needed. Don't mess with hammering out wheel studs and installing longer ones, when you go save time with Project Kics.
* 5 x114.3mm * 12x1.25mm * 25mm thickness * 10mm and 15mm Spacers will require space on the wheels for the original studs. 20mm and up might need space, but it depends on the original studs length. ( If it has been swapped out for extended studs, etc.) * The pictures show a 15mm spacer and how the original stud sticks out. * Notice how the hub face of the wheel has extra holes for the original studs to clear.
Picture shown may not reflect the actual item (thickness)
Note: This is closeout special. Only a couple at this great price. Original price is $150.95 and Now $120.00.
Thanks,FRSport.com Team
AIM: FRSportSalesEmail:
[email protected]
