Project Featherweight v.2011: NICO's Autocross Truck
All over the world, Nissan products are involved in road racing, track days, time attack and autocross.
PEZi
NICOclub.com's Autocross Truck went into surgery this winter as part of Project Featherweight, the SCCA E-Prepared build. The goal was to shed weight, do some balancing and just freshen up a few things. The result? I have a Go-Kart :)
For those interested, here is the build-up from this winter :mike
5 months ago, it got parked for the winter, and mods slowly took place since then
Day 1:
Starting to make progress...
Day 2:
Front lip of sorts added, makeshift fender roll on the already beat fenders and of course... more crap removed.
Day 3:
Who needs this? What is this... a plastic ice-cream scoop?
Day 4:
A quick day... but progress nonetheless
Day 5:
Getting to the good stuff. Passenger side rear fender-well removed
Day 6:
Driver side done as well
Day 7:
Paint! Also... the lightweight floppy door mod!
Day 8:
Front fender tubs come out, and the lightweight floppy hood mod!
Day 9:
Another quick day. Holes cut in the grill for the blinkers and few other minor cosmetic touches.
Day 10:
Another short day. Blinkers mounted and wiring unwrapped
Day 11:
Hood pins and new bump stops installed
Day 12:
Hood pins finally done. JDM hood prop added for cooling, but the hood is so floppy, the middle is still below where it needs to be :rotfl
Day 13:
Rear suspension rebuild ensues, and 2011 fluids arrive.
Day 14:
Rear suspension fully apart, prepped and painted. Front sway bar out.
Day 15:
Front sway bar, rear mounting points and the rest of the rear suspension sprayed.
Day 16:
New bushings in, rear put back together and adjustable spring rate leaf helper added.
Day 17:
Front sway bar back in with new bushings installed.
Day 18:
Maintenance time... hub comes off to replace wheel studs... thanks you Nissan for this crap design :rolleyes:
Day 19:
Battery cables cut to length and master disconnect switch installed.
Day 20:
Brake lines and clutch line flushed and bled, then on to remove OPR off of the Hoosiers
Day 21:
Finally off of stands! Wheels on, wires installed, fuel lines re-routed... all that good stuff. Oil change done as well.
Day 22:
Battery box and battery installed, and, oh, yeah.............. It runs
[youtube]http://www.youtube.com/watch?v=sAR4qZtnmDY[/youtube]
There will still be a few updates this week as final things are taken care of. Results from this season's results will also be posted with in car videos when possible! Stay tuned for this season's shenanigans :werd:
Day 23:
SCCA rules state there must be firewall hole covers.... how about these?
boro drift
Car: '87 Supra, '92 240 with SR20 and '98 12 valve Cummins
I wish you luck in the 2011 season, my friend. Let me know if you need anything else for the truck.
PEZi
Thanks buddy! Love the battery box!
Rev_D21
1991 D21 Reg 2WD Auto
1995 D21 Reg 2WD 5Spd
1996 D21 Reg 4WD 5Spd
2012 Versa 1.6S 5-Speed
She's a full on race truck now.
sbird1
Car: 2006 BMW 325i
Full race indeed. Is it still street legal at this point?
PapaSmurf2k3
Site Admin
Cool!
Any idea on the total weight savings?
flinterman2000
Car: 2000 Nissan Wingroad, 85 Datsun 720 Pick Up.
I'm glad I was able to help you remove some of the weight.
PEZi
sbird1 wrote:Full race indeed. Is it still street legal at this point?
Its got tags :couch:
PapaSmurf2k3 wrote:Cool!
From this winter, a tab over 150lbs. Dunno about overall, but stock curb weight was around 2580 and I'm estimating 500. That puts it about 2k :)
flinterman2000 wrote:I'm glad I was able to help you remove some of the weight.
Yes indeed, in my most memorable shipping experience thus far :rotfl
PEZi
Original post updated with day 23!
nissangirl74
You finally did it. Well done! ;)
longtooth
Car: 89 d21 HB
Sweet job. The video was too short however.
300ZXttZMAN
yea that looks cool i want to see a longer video tho :)
PEZi
Due to some unfortunate wiring issues... the truck is back down :(
It should be up and running again before July 9th's event however!
flohtingPoint
Car: 2004 Z16 Corvette Z06
PEZi wrote:Due to some unfortunate wiring issues... the truck is back down :(
It better!
BTW, have you registered for all your contingencies yet? http://www.scca.com/contingencies.aspx?hub=3
PEZi
flohtingPoint wrote:
It better!
Gettin' around to it!
PEZi
For those that weren't quite able to make it out for the Rocky Mountain ProSolo, here's the damage!
Return to “Nissan Road Racing / Auto X Forum”
