Project Stealth b0mber (AKA Project Ebay)
Postby ZOMG.SR20 » Sat Jan 17, 2009 8:11 am
Let me just start out by saying i missed the 240 so much i had to go out and buy another I think i did good this time
I had this
Sold it now i have a
Its a 1993 S13 Hatch Base with a SR20
and i am not telling how much i paid because their will be a mutiny
tell me what you all think my plans in the next couple of months is to
1. get it running
2. install Stance GR+Pros to get rid of the blown struts (4x4 ftl)
3. TBA
Modified by redneck90m at 1:38 PM 1/17/2009
Modified by redneck90m at 2:03 PM 1/17/2009
ZOMG.SR20
Car: 2001 VW jetta 1.8t
Re: Project Stealth b0mber (redneck90m)
Postby jazz4890 » Sat Jan 17, 2009 8:35 am
isnt that black 240 from the guy who was doing project ebay? if so then i guess he decided not to go through with his project which sucks cause i was actualy pretty interested in that thread.
Quote, originally posted by fukin240 »
I found Half a smoked joint, a paper clip, and a penny.
McGiver drove my 240...
10k? no way that was a 10k 240
240 owners are NOTORIOUS diy guys
that 240 prolly cost in the range of 5k car included.
haha so true
jazz4890
Car: 1991 Nissan 240sx
Re: Project Stealth b0mber (jazz4890)
Postby ZOMG.SR20 » Sat Jan 17, 2009 8:37 am
yea and i bought off of him in my effforts to get it running
ZOMG.SR20
Postby turbo2nr » Sat Jan 17, 2009 8:45 am
OO00000000000OOOOOOOOO yeeeeeeeaaaaaahhhhhhhhhhh
shift_BOOST
97 s14
BOOSTED
turbo2nr
Car: 97 240sx (kouki)
Postby jazz4890 » Sat Jan 17, 2009 9:05 am
haha thats cool have you figured out the problem yet? is everything already installed on the mototr or is there still some stuff left to be done? and is it not starting or is it just not idling?
jazz4890
Postby ZOMG.SR20 » Sat Jan 17, 2009 9:26 am
Everything is DONE it cranks and cranks but wont start i haven't had the chance to tare it apart since i havent been able to go pick it up yet (I need a trailer....)
ZOMG.SR20
Postby jazz4890 » Sat Jan 17, 2009 9:33 am
alright well its good that its in the car already the first things you should start with are the basics check to make sure your getting fuel to the motor make sure your getting spark check your coil packs they tend to go bad a lot and make sure your getting air to the motor check your mass airflow sensor make sure its wired up correctly and also check your cam angle sensor a lot of times these motors dont have the timing done right so you definetly wanna check to see if your timing is off. check all of that and let me know whats up after that.
jazz4890
Postby ZOMG.SR20 » Sat Jan 17, 2009 9:49 am
will do thanks man
ZOMG.SR20
Postby Bumnah » Sat Jan 17, 2009 10:00 am
So project ebay ended because the motor wouldn't crank? Seems kinda like the obvious end result.
Quote, originally posted by David Cross »
All my friends are always telling me how hard it is to have kids. 'Oh, David, it's so hard.' That's not hard. I'll tell you what hard is. Try talking your girlfriend into her third consecutive abortion. Yeah, that's hard, that takes finesse. You’re just inconvenienced.
Project Eva - The Track Package
My Garage > Your Garage
Bumnah
Car: 1992 240SX, black. Bone stock.
Re: Project Stealth b0mber (Bumnah)
Postby ZOMG.SR20 » Sat Jan 17, 2009 10:09 am
it does crank it gets spark too just wont run also must stress the motor was not bought off of EBAY
ZOMG.SR20
Postby jazz4890 » Sat Jan 17, 2009 10:35 am
alright now check to see if its getting fuel check your fuel pump and check to make sure your injectors are spraying fuel and make sure the fuel lines are all connected right and make sure you dont have any lines wrongly connected meaning going somewhere there not supposed to. then check to make sure your maf is good and its wired right the maf is one of the main problems why it could crank but not start and dont forget timing and make sure your cas is good to and the wires are all connected right that are going to your cam angle sensor(cas).
jazz4890
Postby ZOMG.SR20 » Sun Jan 18, 2009 3:15 pm
ok new one, how do you adjust timing on the SR? cause me no see no distributor
my guess because it does exactly the same as this
http://www.youtube.com/watch?v=nbGUVajCDks
ZOMG.SR20
Postby jazz4890 » Sun Jan 18, 2009 5:08 pm
Haha its the cam angle sensor I have circled it in red in this pic you can advance or retard timing with this its just like a distributor thats for simple timing for more advance timing your going to need to advance/retard the cam shafts, by taking off the belts and re adjusting them....be careful not to bend valves and make sure the marks on the pullies all line up.
jazz4890
Postby ZOMG.SR20 » Sun Jan 18, 2009 5:41 pm
would a bad CAS cause the above mention running wrong if so where do i get a replacable one like which USDM car ....... i sound like a noob when it comes to these fancy SRs
ZOMG.SR20
Postby Elbowblk » Sun Jan 18, 2009 5:50 pm
Hows the avenger treating ya? probally decent in snow right?
Elbowblk
Car: 95 240sx
Re: Project Stealth b0mber (Elbowblk)
Postby ZOMG.SR20 » Sun Jan 18, 2009 6:11 pm
dont no dont drive it it sitting in the yard with a for sale sign and ive had 9 people look at it and 5 have called back and 1 has kept asking about the other offers and well its at 2000
ZOMG.SR20
Postby NismoDriver240 » Sun Jan 18, 2009 8:30 pm
Bumnah wrote:So project ebay ended because the motor wouldn't crank? Seems kinda like the obvious end result.
yea totally obvious
your so fking ignorant.
Project eBay ended because I got a job, money for a dependable, warranted, all season vehicle, and bought an STi.
Good luck with it Jacob. Looking good for a thursday pickup.
NismoDriver240
Car: 2005 STi
Re: Project Stealth b0mber (NismoDriver240)
Postby mrgreeneyes » Mon Jan 19, 2009 12:16 am
NismoDriver240 wrote:
yea totally obvious
you are so awesome. you got a big boy job. have fun with that
PARTS FOR SALE:
-OEM SR20 Redtop ECU, works great, came off a running swap.
mrgreeneyes
Car: ///M5
Parted Out Built S13 Coupe
Re: Project Stealth b0mber (mrgreeneyes)
Postby White Comet » Mon Jan 19, 2009 3:40 am
i like where this is goin
Quote by mrgreeneyes »sorry i cant satisfy you, jeff
White Comet
Car: fc, s13 and mazda6, Sierra
Re: Project Stealth b0mber (White Comet)
Postby addisonblck » Mon Jan 19, 2009 6:13 am
that does suck that it ended...i was watchin that.
op: good luck with it man
i got censored
addisonblck
Car: 93 se mods soon to come
Sc300 1jz swap laundry list of goodies
Postby NismoDriver240 » Mon Jan 19, 2009 8:43 am
Cute
It's funny, before I bought an STi, all the owners were complete douche bags, and I had a 240 and was cool with nico. Now, STi owners are normal people and it's looking to be that time of the month for nico members... well, at least one.
Did I touch a raw nerve with you? Or are you the type that makes others hate certain car communities because of the way you treat non-owners? Once you grow up, in the mental aspect, not age, you'll see that it is just a car.
NismoDriver240
Car: 2005 STi
Postby Flicktitty » Mon Jan 19, 2009 9:51 am
Cute
It's just Nico man, And when my brother owned a STI i couldn't believe how nice sube guys are. I'm sure it has alot to do with jelousy, I mean you went from having a 240sx that was built through ebay, to a NEWish STI.
speaking of which, you should post up some pics somewhere and what the plans are for it (if any) Congrats on the purchase.
1989 Nissan 240sx Coupe: 19,000 Original miles 2JZ-GTE / Titan 3500 stall / AEM EMS V2 / PT6266 / ETC
Flicktitty
Car: 1989 Nissan 240sx 19k Miles.
Re: Project Stealth b0mber (Flicktitty)
Postby kevinphan » Mon Jan 19, 2009 10:01 am
Some pics of Jesse's(NismoDriver240) STi.
kevinphan
Car: 1991 240SX SE
Postby Dittoz7 » Mon Jan 19, 2009 10:01 am
Good To See Ya Back Jess.
Saw The Rallyx Vid.
Dittoz7
Car: 1997 2f0WtY SE!
Re: Project Stealth b0mber (kevinphan)
Postby Ghast » Mon Jan 19, 2009 10:18 am
Ahhhhhhhhhh I hate to be the one to go off topic, but that STI is sick.
My gf wants one but i have not taught her how to drive standard yet.
They are safe! quick, and pretty reliable as long as you maintain it.
Beautiful car.
Very awesome nismodriver240, Congratz on the better job and congratz on making a smart purchase. Warranty is the exact reason my friend just sold his 97supra and MR2 to get himself an EvoX. Once i finish school i too will upgrade to a better paying job and buy myself a better daily driver. I would still like to keep the 240 as a project, besides in 4 years its a classic car. Something about that makes me want to keep it haha.
My favorite Subie video (( http://video.kenblockracing.com/flash/player/ )) Ken block during Gymkahana practice.
OP, First let me apologize for going off topic. Everything looks good so far! Keep us updated on the Running status!
One Love,
Ghasty
"All action results from thought, so it is thoughts that matter". - Sai Baba
Ghast
Car: 1993 240sx, 2002 Lancer ES, 2006 350z Enthusiast
Postby nevertheless » Mon Jan 19, 2009 11:06 am
Are you going to turn this car around, with quality parts?
nevertheless
Car: 1993 240sx hatch
1995 Nissan D21
Re: (nevertheless)
Postby Flicktitty » Mon Jan 19, 2009 11:43 am
nevertheless wrote:Are you going to turn this car around, with quality parts?
this coming from someone who was gonna run KSports....
Flicktitty
Re: (Flicktitty)
Postby nevertheless » Mon Jan 19, 2009 11:54 am
that was along time ago
nevertheless
1995 Nissan D21
Re: Project Stealth b0mber (Dittoz7)
Postby NismoDriver240 » Mon Jan 19, 2009 12:20 pm
haha yea I've been lurkin a lil bit, might as well post up now and then.
don't mean to steal your spotlight Jake.
Cardomain: http://www.cardomain.com/ride/3183340
First ever rally even on all season tires and 90% ice: http://www.youtube.com/watch?v=aUdlH-pr8Hs
Thats all I got for now
NismoDriver240
Car: 2005 STi
Re: (nevertheless)
Postby mrgreeneyes » Mon Jan 19, 2009 12:38 pm
we can only hope. and he can sell all the junk parts... ON EBAY!!!! return it to its home.
nismodriver. you get butt-hurt too easily. the sube is nice. a car with a warranty does not make one mature tho. it just means you can whine to someone else when things break. not my cup of tea.
but then again im the immature type that likes to work on my own car.
either way, OP, good luck rescuing this damsel in distress. shes an ugly cheap whore right now, but you can make her pretty and classy
whats funny is i probably hang out with more sube owners than you do. just cus i own a 240 doesnt mean i worship it. ill admit its an oldass "sports" car. i am part of a healthy touge scene in my area, i dont care what car you drive, what matters is you are pushing your car to its limits through curves, and having a blast, not hoping that the dealer will warranty my car if an OBD check engine light comes on.
how much of your own work have you done on your sube? what wheels are those? exhaust?
mrgreeneyes
Car: ///M5
Next
Return to 240sx General Discussion
