Progress on the Spec-V wheels
The Nissan Versa Tech Discussion forum is the place to discuss Versa performance modifications and maintenance.
blindsnyper
Car: 2007 versa
Promise Land wrote: BlindSnyper can't be the only celebrity among us.
car looks good.
i suggest........coilovers, :rotfl
Promise Land
Car: 2011 Nissan Versa
2001 Chevy Suburban
1992 Ford Mustang
Promise Land wrote:
Atx_Versa wrote:Finally! Looks really good, whats next???
Not jumping on the S/C kit or coilovers bandwagon just yet. Has to be different and original.
There fixed it. :slap:
ADOversa
Car: 2008 Versa S 6MT Hatch, 2005 Chevy 3500 LWB
Hey do those wheels fit on the Versa without spacers/adapters? Just bolt on like normal?
carlos15
Car: 09 versa sedan 1.8l
window tint
white footwell lighting
1993 miata
ebay exhaust
greddy turbo kit
ebay interfooler
megasqrtui
you could always get new cams and injectors maybe you could have a company make those! :)
Promise Land
2001 Chevy Suburban
1992 Ford Mustang
ADOversa wrote:Hey do those wheels fit on the Versa without spacers/adapters? Just bolt on like normal?
You will need 5mm spacers on the front to clear the front calipers. I am running them on both front and rear.
Promise Land
2001 Chevy Suburban
1992 Ford Mustang
carlos15 wrote:you could always get new cams and injectors maybe you could have a company make those! :)
Cams are a thought. Not sure if I want to spec them for a 1.8L or for a 2.0L if that would make a difference. Still thinking long-term (like 3 years down the road) for a built MR20 swap. Still would like pistons and rods to go with them.
I bet there are already injectors out there that would fit the Versa. It's a matter of determining what size you need.
carlos15
window tint
1993 miata
ebay exhaust
greddy turbo kit
ebay interfooler
megasqrtui
Yeah true and I like the built mr20 idea
ADOversa
Cool... so they just fit like normal other than that? Where did you get these? I really want to get a set for my Versa.
Promise Land
2001 Chevy Suburban
1992 Ford Mustang
They fit fine with 5mm spacers. Nothing else needed. I added some chrome lugnuts from an Altima to go with the chrome Nissan emblem.
I bought mine from the classifieds on NICO from another member. They are hard to find, but be patient enough and another set will come up. Don't be afraid of curb rash. Just make sure they aren't all bent up and out of round. Rash is easily fixed with some work, but anything more is not easily fixed and not worth the money.
I think they are selling reproductions on ebay for $400/set + shipping. Not too bad. I got mine for $375 shipped and then put another $75 into materials to fix and paint them (plus ~50 hours of work).
ADOversa
Yeah I saw the reproductions on ebay and have been tempted but would prefer the real deal. Going to start checking wreckers around here... probably a really long shot but it can't hurt to ask.
I have also been looking at Konig Incident's too... they also look awesome.
What years did these wheels come on the spec v?
Thanks for the info!
Promise Land
2001 Chevy Suburban
1992 Ford Mustang
ADOversa wrote:What years did these wheels come on the spec v?
2001 / 2002
ADOversa
Thanks!
aplversa
Gonna be painting mine soon. I'm using paint stripper to save me some time sanding the clearcoat, the cold weather is delaying the dwell though, hasn't gone through the base. I was gonna order the spacers from M2, but my friend gave me his unused set, same 5mm. I'm gonna use Bondo Plastic Metal for the curb rash and nicks.
D3stro
ADOversa wrote:Yeah I saw the reproductions on ebay and have been tempted but would prefer the real deal. Going to start checking wreckers around here... probably a really long shot but it can't hurt to ask.
2002-03 SpecV had these 5 spokes wheels. Made by TSW, they are know to be fragile. Plus, they weight 24lbs each, that's heavy for a 17x7 wheel.
LavaDriver
Car: 2008 Nissan Versa
planning on tuning
getting ideas...
hi,
i'm planning on using the same wheels and just wanted to verify you're only using the 5mm spacer for the front?
the rear doesn't need any additional equipment?
thanks for your help!
D3stro
LavaDriver wrote:hi,
Yup, 5mm for the front. You may get some 5mm too for the rear, you'll get a +40 offset on four corners that way.
LavaDriver
planning on tuning
getting ideas...
hi,
tried mounting these with the 5mm spacer, and i don't have enough threads!
someone suggested extended lug nuts, but i've heard different stories about these...
are they safe? has anyone used them on a SpecV rim? if you have, please let me know the specs of the nut you used...
thanks!
Promise Land
2001 Chevy Suburban
1992 Ford Mustang
you shouldn't need extended lugs. I used the nuts from a newer Altima. Same thread as the Versa.
LavaDriver
planning on tuning
getting ideas...
well, when i installed the wheels with the 5mm spacers, i could only turn the OEM lug 4.5 turns...
tried to install with extended thread lugs nuts and got 6.5 turns, but because of the taper at the wheel hub center, the wheel is no longer hub centric, but now lug centric...
while i know there is really nothing wrong with lug centric wheels, there are some instances where a large wheel hit damaged the wheels studs, and i'm already well over my budget... with the way things are going for me, i'm almost certain this will happen to me... like i said, it's probably safe, but for my own piece of mind...
all that being said, i've got a set of Spec-V rims for sale... any takers... email me at [email protected]
Return to “Versa Technical Discussions”
