jeffadamshti wrote:I de-programed it, here is how to fix it if anyone ever needs to re-program a nissan key fob. Car is still stalling, could it be ECU, radio face went dead, still plays but its so hot..? Might be fule filter.
I recently had to replace my remote, but I was unable to find anywhere on the Web the instructions for registering the remote unit with the car's computer. I eventually obtained the following instructions from an Infiniti Dealer and I have posted them below.
1.Get in & lock the doors2.Insert the key into the ignition 6 times within 15 seconds3.Hazard lights should flash4.Put key back into the ignition & turn to Accessory5.Press the master door lock (on drivers door arm rest) unlock/lock6.Hit the lock button on the remote7.Hazards should flash8.Pull key out and open the drivers door and then close it 9.It should be set
These instructions worked perfectly for me. If you have more than one remote, I believe that you repeat step 6 for each remote before performing step 8. However, I have not tried registering more than one remote.
Just a note on the key fob programming.
I have a 2005 Maxima, and a 2007 Frontier (just purchased). I found that I could program my Maxima key fobs to work with my Frontier. I just used the proceedure above and it worked great, Now I only have to carry one key fob for both vehicles.
I don't know how many can work together but both of mine were the same shape, the Maxima had an extra button for the trunk, and the dealer said it would not work, but I had to try it anyway.
Also the procedure above does NOT erase all the codes, it just allows the programming of a new fob.
The procedure I used was a little different.according to my dealer I did step 4 (skipped step 5) and then step 6 After the hazards flashed, If you don't need to program any others, do step 8, if you need to program another, do step 5 and then 6. do this until all fobs are programed (Four MAX). Then do step 8, then you are done.
Cheers Jim
