the brake light bulbs are the same as when i bought the car...nos487 wrote:Check brake light bulbs. Also look inside tail light area.
usually if its the sockets the lights will be dim, but i looked at them anyway and nothing...hboninc19 wrote:Are you using the correct light bulbs? And check all the bulb sockets
ill look tomorrow... where is the switch located? i have the alldata diagram and it show s a connection after fuse and then the switch... or is the switch located where the pedal is?locoluna825 wrote:at the pedal switch, that's where it usually happens. make sure the wires aren't melted together. and try swapping out the switch.
ill take a better look at it, cuz if this isnt it i have no idea and am stumped on where the short is...locoluna825 wrote:if you worm up under the dash you'll see two switches if your car is equipped with a cruise control and a only one if yours is not. ittle be just above the brake pedal under there.
i just tried that... didnt work... im stumped... i think the short might be somewhere in the hatch door...iandrew89 wrote:i had something like that happen in mine. We came to the conclusion it was blowing the fuse whn my hatch was shut so far. I couldn't figure out what it was but i dont blow fuses anymore after disconnecting my rear window defroster.
before i went to bed last night i thought about that, my hatch brake light doesnt work anyways so im gunna disconnect that brake light where the passengers interior armrest is...djmonkee wrote:open your hatch and check the wires in near the roof. the ones in mine broke from being opened and closed so much
