blazncypher wrote:I have a friend who builds race cars and he told me that unless you drive a really high end car (porsche, ferrari, lambo, bentley, etc.)
He's partially right. But it's not the brand that determines it, it's the engine. The VQ isn't one that NEEDS premium. It can benefit from it, but doesn't need it.
Most newer engines don't require premium. Unless they're in something making a lot of power, or they're turbo, there's nothing to need premium for.
Remember that octane is a measure of resistance to knock. Modern cars can compensate for knock by retarding timing (which decreases power). However, LOWER octane fuels have HIGHER energy content. The problem is, most high-power motors have high-compression (or are turbo or supercharged, which equates to the same thing), and are more prone to knocking, so they have to have high-octane fuel to run properly.
Even the VQ has high enough compression that low-octane gas risks knock. But retarding timing combats that. Jltibbs is right that the effects of running at "normal" timing are better on the engine, though.
allensteiner wrote:**** got heated up in here:) us premium fuel is crap as it is, lowest octane numbers in the civilised world!
That isn't because of fuel quality. It's for two reasons:1: We use a different octane listing system than the rest of the world. We list an average of two numbers rather than the higher of the two like "the rest of the world" does.2: Our altitudes in many places mean lower-octane is equivalent to higher octane (this is the same everywhere, but when you're comparing high altitude to low altitude, it makes things look worse than they are). 91 at high altitude is as good or better than 93 at sea level. We're so high here in SLC that you can even buy 85.
chrunner09 wrote:I've been using Plus for quite some time, and i mean, $.10 is really going to make THAT much of a price difference.
Exactly. Even with my car's HUGE 22 gallon tank, It's only ~$4 per fillup in the worst case. Totally worth it for me. When it's taking just under $90 to fill up, what's another $4, eh? MAYBE 25 bucks more a month to run premium isn't that bad.
But again, I'd rather keep people informed than be another "nooooooo...only run premium or you're going to hell" kind of guy. Not that anyone in here's been that way.
