Too much camber even.
Alignment has a play, if you wheels are not aligned. And if your chassis has any lose bits such as ball joints, rubber bushings, and chassis flex.
The 300zx suspension is like double wishbone, but that isn't the correct term. But it's behavior is very simular. This picture can illustrate it.
You can imagine as you load one side of the car that will be the suspension travel, more negative.
Once the car is turning a corner the tire experiences a side load, this is called laterial load. If the tire was vertical and under enough load, the tire will tip more positive chamber. This means you just lost contact patch of your tire. But with initial camber, you can regain/maintain the patch.
It does offer better traction if set up correctly. But there is such thing as too much camber, ie less contact patch.
The thing about traction is tire slip angle. The way you can notice slip angle is on a windy day, on the highway. The wind is coming from the head and right side. You as a driver has to turn the wheel to counter act the wind. The steering angle will be toward the wind, and the slip angle is going the direction of the car.
In cornering, it's whats keeping grip and allowing you to turn the corner. More slip angle, more lateral force your tires offer. In other words, the more your tires can deform, the better the tires can hold the car's side forces.
The tire, suspension, and chassis dictates how much slip angle the tire can handle. Once you reach pass this limit, it's loss of traction. For instance, if you are cornering and your front tires slip angle maxed out, the car would plow in the forward direction, understeer. Oversteer would be that the rear slip angles has had it. In vehicle dynamic world, it's much more desirable for the car to understeer than oversteer. Reason being is that the driver can change the angle of the wheels in hopes to regain traction, oversteer the driver is hopeless. It's a werid concept grasp, but they deem it "stable".
Street cars have limited traction, they call them the "1-G" tire. Because whether it's braking, accelerating, or cornering, it usually maxs out at "1-G". This is from the tire's compound and sidewall stiffness.
Have you ever heard someone say that thinner tire wall can be bad? They are right, because the thinner wall means stiffer side wall. The stiffer the sidewall of the tire, the less the slip angle available for the tire. Additionally, this stiffer sidewall can affect how much camber affects you. So avoid low profile tires.
There isn't one size fits all for traction. And there isn't a magic that get's you instant traction. Many car manufactures and racing teams send countless hours shaking down their cars to get the optinum traction out of their cars. They test different settings in a comparitive manner to determine if they are handling better.
I would also not compare to your friends s14 either, your car is much heavier. Which means your tires need to counteract the more forces your car offers. The secert to shock set up in racing cars is low frequency dampening, softer setting. You want to crank them up, high frequency dampening, when you are going BAJA style. But my recommendation would be check above items, and adjust your caster and shocks via trial and error.
