Powered By Ford
Powered By Ford
Postby BlackZenki82 » Tue Jun 26, 2012 10:29 am
Hey guys!!! remember me!?!?!?
Well NICO, I figured it's time to share another one of my in depth builds with you guys... I haven't really been on much lately, but I've been out of the game for a while, crashing cars, and building GTR's and stuff.
So yeah, a couple things to get out of the way... YES, this a ford engine, NO, I don't care how much better you think a LSx is. NO, this is not going to be "bawlah" build, it's going to be a budget oriented "every man build".
I think that this build needs to be seen by the masses, and not kept to myself behind garage doors...
So, onward shall we?
I went and got me a fancy S14 shell, figured I needed to do something neat with it...
Origin 30mm front fenders
Origin Type II 50mm rear over fenders
Origin Stylish side skirts
Chaser "Stylish" front and rear bumpers, front singnals/side markers deleted (he decided to cheap out on these due to not wanting to destroy $$$, I agree)
Chaser Hood, fits like s***.
rear trunk gutted to bare skin and tail light panel.
Here it is...
Engine bay is completely wire brushed to bare metal, and cleared over to keep the rust away. I'm going to tub the wheel wells, and call it a day in there.
Current paint sucks, the rainbow flake sucks, the clear sucks, and since I'm going to be driving the living s*** out of this car, I've decided to sand her down somewhat smooth, the wrap the entire car in vinyl, at least that way, when I hit s***, my Origin body stuff wont explode into 5.6 million peices, it'll hold it's shape, and look better than some zip tied fiberglass frankenstien BS. Color is TBD.
Interior is pretty straight forward, and spartan.
front end fit like s***, not due to Origin's quality, but due to the previous owners half assery, so I took some time to get everything lined up the way it should be, lot of FG trimming and sanding. I'm still not done, but got the majority of the front end lined up half way decent.
What it looked like before, as a point of reference for you guys...
I took the chassis harness, and brought it down to bare essentials... pile on the right is the leftovers...
Stripped down the steering column, lost all switches, so I made my own panel. Still needs a tad bit of work, maybe another couple of switches, but whatever.
I just picked up some Driftworks lower control arms, they should go well with my PBM inners w/rack spacers, SPL outers, and modded knuckles.
so yeah, pretty cool as far as the shell goes... now, lets get to the part that I'm sure you guys are like "what the f***?" about, the powerplant.
My choice of engine is the quad cam, all aluminum 32 valve 4.6L Lincoln MKVII engine, or three..
... basic run down? I have two different engines, both MKVIII's, one is an earlier model, rated at 280hp, and 285tq, which will be used as a test mule/mock up engine. The jewel is the 1998 InTech, or Teksid block engine, rated at 290hp, 295tq in stock form. These motors are basically a detuned Cobra engine, but all aluminum, VS cast iorn. The pretty much the only difference between these, and the N/A cobra motors, are the intake plenums. Since the non InTech engine is going to be a mock up dealy, I'm building the 1998 Teksid for superchargationz. Basically utilizing the stock SC set up from a 03-04 cobra, crank, pistons, and rods, all of which can be had for pennies on the dollar, and are stable to 600+whp. Now, you might be saying "Look at the size of that thing!!", well, I get that a lot, but in reference to the engines, yes, they are wide, yes, there will be clearance issues, and no, they're not that effing big... a DOHC is actually proportionately smaller than a VH45, AND only weighs roughly 50-60lbs than a KA24DE.
Onward... In my trip to go pick these motors up, I took the other non InTech motor that was in the better shape of the two, and traded my friend for a 01+ Mustang GT 5spd trans with some cash on top, which helped with the initial cost of the motors, and I got the trans I need out of the deal. It's a Tremec 3650 5spd, good for some repectable power numbers. I also scooped up some 4.5" Ranlet Blast pipes/muffler, and some Driftworks front lower control arms..
checked the trans/engine fitment (just to make sure you know), and everything was spot on.
Got home at around 5am, unloaded car s***, and hit the sack.
Next up will be a OEM twin plate cobra clutch, and lightened flywheel, once I get everything mated up proper, I can drop the motor in the hole, set it where I want it and start fabbing up some motor/trans mounts.
Cobra cranks are forged, OEM MKVIII's are cast, so yeah s***. OEM bottom end is limited to around 400hp, then it want's to fly apart. Good thing all cobra parts will bolt right in, and are readily available. I found a Cobra crank for $250, forgot what brand, but used H beam rods for $300, and OEM cobra pistons can be had for around $150. Set up like that would be near bullet proof.
Basically use cobra internals, 03-04 supercharger set up, small pulley, exhuast, and a decent tune, and it should be up to around 600 on pump, daily driveable (remember, it would still be relatively "stock"), like a large number of "Terminator" owners have. Only difference would be the Aluminum block from the Lincoln.
Another bonus, is the stock 03-04 cobras have OEM twin plate clutches, found a used one on ebay with around 1,600 miles for $300 shipped.
Stock EFI for now, might run something a little different with the SC build though.
Lots of ford transmissions bolt up, you have your T5, which the MKVIII would destroy, the 01+ Tremec 3650 (what I have), and the Tremec T56... other options as well if you're running AOD/E, C4, etc etc... transmission options are pretty much endless in the A/M.
Got the InTech pulled down, and cleaned up a bit. I pulled a valve cover to check the heads, not bad at all, no sludge, minor carmelization nothing notable. The regular engine is still in the corner, like a neglected child. These are some fairly large engines for such small displacement....
Before...
After...
I usually stay away from the domestic swaps too, especially the LSx's. Like dude said, recent demand has made the prices skyrocket. Little do people know, that the MKIII's make roughly the same power (InTech engines), and have been driven by some old man to the golf course, not by some mullet ragging the s*** out of it for the last 15 years. So it would probably make MORE power on a dyno hahah...
Springs are still closed, so in my frustration, I went to the garage and opened a can of elbow grease...
After...
I wish I had a decent pressure washer, and some aluminum stripper, but it's good enough now to keep my hands/work area clean while I mock stuff up. Both engines are next.
I know some people are like "Dang, that's a big ol' engine in a little bitty car!", well, here's some knowledge that I've been sitting on since before I decided to do this swap......
S14 strut towers....
S14 frame rails...
DOHC V8...
Another mans unfinished attempt at this swap...
Eat my shorts nay sayers....
I began my path looking for a EFI 5.0 and T5. Then I went to the junkyard, and found this MKVIII and was like "wait, wut? alum DOHC 32v?" why go for a $700-$800 210hp 5.0, when you could spend $200, get 300hp, with one of the most sought after 4.6L blocks? That was my reasoning, cost, AND out of the box power. Not to mention an endless aftermarket like a SR20.
MKIII engines are rear sump too... I saw a Merc Marauder front sump conversion for BNIB for $200... figured maybe since the Merc is front sump, so would the Ford Crown Vic it's based on. Just haven't delved any deeper into it... maybe I will now... might be $20 at the bone yard from some old cruiser, save $180.
I'm still shooting for fire up/driving to end up costing less than a SR on a pallet. Right now, I have two engines, and a TR 3650 5spd for less than $400. I can pull down the one engine, and sell the bare block for $500 alone.
Got a few things knocked out today...
Core support drilled out to make life easier mocking up mounts for the 32v, also threw some purple power at it to clean it up a bit.
Might have to go tube front on this car, it was always an option, but never a requirement... now it's looking to be the latter, as you can see, the core support is a bit boogered up...
I was lucky enough to scoop up an intake for my throttle body. Unknown brand, but was told it came with some aftermarket supercharger kit for our buddies 07 GT500.
Then, just screwing off in the garage, I found that a S14 5spd trans cross member is awful close to being perfect (redrill mount holes, woopdy doo!).
Now I'm just waiting on my buddy's hoist to be freed up, then it's time to make mounts and get this big bastard in the hole....
Sharingan 19 wrote:Don't you love it when a plan comes together. That steering assembly looks like it comes over at a pretty aggressive angle (since ka's are do narrow) to meet the rack. Any anticipated clearance issues in that corner?
This actually looks like less of a pain in the a** than the vh45 and doesn't have that hideous intake manifold :lol:
It is nice when things seem to fall into place in unknown territory...
steering colum/oil pan are the main two issues. Oil pan is possibly being solved with a crown vic front sump pan. As far as the rear goes, I explained it best on another forum, as I've been asked that several times, so I'll just quote here.
Blackzenki82 wrote:On the MKVIII Lincolns, you have to remove the steering shaft to get the motor out... there's a good sized opened made on the OEM headers for the shaft to go through. As soon as I get my bro's hoist over here, I'll be doing some test fitting to see what kind of clearance issues I'm going to have. Might have to do something drastic, who knows, I'll cross that road when I get there...
1998 Teksid...
1996 Teksid...
Appears to have more clearance with the 1998 header... both headers on the passanger side are cast iron, block huggers, only the driver side extends...
Who knows, might be a perfect fit.
Figured it was pertinent info for the build on this forum.
well, back to the chassis....
I knew that the arch cut outs for the rear were kind of rough, but I had no idea. I pulled the 50mm overs off, to get em prepped for wrap, and to fix the arch cut outs...
Check this out the prev owners work at it's finest.
You guys didn't know that expanding foam sprayed randomly is just as good as a weld?
well, looks like I have some work ahead of me, redoing EVERYTHING....
This post is Approved by Jaws.
Don't worry bros, I got this....
Traded out my "stylish" aero, for something a little more agressive...
AIT URAS Type 4 cow plow...
Might as well tube chassis with as much fiberglass I'm throwing at it.
Did more stuff and things...
This AIT/URAS Type 4 actually fits fairly well, for being rep/knock off aero...
I'm going to love the look I think, perfect amount of aggression for my choice in motor I think...
Beiber aka Eric Conkling learning how to get his flux weld on... JAY BEIBS!!!!
Oh, and I got a new coffee pot, available only at walmart (in ricky bobby voice).
Next up on the to do list...
I'm probably going to have a professional do it, so it doesn't end up looking like s***.
It's neon green, I was going to roll it out in sunlight, but Debby's out there dumping a** loads on rain on me..
here's another shot, still off, but better represents the color...
Quote, originally posted by s13Addict »Don't you like... not have a license? hell yeah dude. Breakin the law with a cop in the car... that's BZ.
BlackZenki82
Car: 1991 Nissan Skyline GTR
Re: Powered By Ford
Postby CJH » Tue Jun 26, 2012 11:52 am
Wow, sick. I love the work and the idea. You don't think it will be too front heavy? My S13 came with a 302, but I sold it because I didn't want my drift car to be a donut machine.
Come Join Midwest Drifting! My Build
http://www.clubfr.net cj-s-build-t425480.html
CJH
Car: S13
Re: Powered By Ford
Postby kouki munster » Tue Jun 26, 2012 3:55 pm
I've got a pretty sweet collection of parts to do this exact swap, and have been considering selling them off to go in a slightly different direction, so if you happen to need some 03-04 cobra heads, timing cover, pulley bridge, and complete accessory setup shoot me a pm.
I also know for a fact that the Lincoln continental oil pan is front sump, will bolt on, and will require a small notch to be cut out of it or the cross member.(depending on how far back you place your engine)
s14, not being shy anymore 397hp and 316 ft/Ibs, makes 300+ ft/Ibs from 4200-6900 rpm. :biggrin:
04 F-250, 7,500 pound whistlin water buffalo.
kouki munster
Car: 97 base 240
Re: Powered By Ford
Postby Josh@NSP » Tue Jun 26, 2012 4:20 pm
Very nice work! I'll be looking forward to the finished product.
Josh@NSP
Car: Nissan 180SX
Re: Powered By Ford
Postby Lobo240sx » Tue Jun 26, 2012 5:41 pm
Nice build. I hope you are changing that rear end out though. Hell my T70 SR20 destroyed the rear end near 300whp on the dyno. Couldn't imagine what that torque monster is gonna do. :D
T70, 550cc's, Boost Logic Custom Manifold
R.I.P S13 Blacktop
280whp @ 15 PSI
???whp @ 20-22psi
"Built For The Human Race"
Lobo240sx
Car: 1990 Nissan 240sx SR20DET Red Top Rebuild
1995 Toyota Slorolla. 5spd. I\H DD
Re: Powered By Ford
Postby BlackZenki82 » Tue Jun 26, 2012 5:48 pm
Munster, I may be interested,let me think on it... right now I'm still in the early stages (I also remember seeing you on the other MK8 swap build that was never finished a couple years back). I think you should continue with it.
lobo, just going to weld up the R200, and hang it up, if it blows, I'll find a R230 and weld that up (or install proper LSD).
BlackZenki82
Re: Powered By Ford
Postby kouki munster » Tue Jun 26, 2012 7:14 pm
Well, right now everything is on hold until I get a job where I have time(and monies) to play, but when I pick back up there will be a 4 cam ford v8 involved, just not sure which one yet.
kouki munster
Car: 97 base 240
Re: Powered By Ford
Postby 4cefed » Wed Jun 27, 2012 8:55 pm
Nice build. I think the popularity with the Chevy LSx engines has to do with the heads. Since they are pushrod the have a much lower profile and are easier to fit under the hood. Those four cams on your Ford need room to work. I'm really curious to see how far up this thing sticks out of the engine bay. I doubt this is going to be a problem for your build though. I don't see much that's going to be stock.
I have been thinking about some kind of a v8 swap and I was trying to think of an all aluminum v8 for cheap. I'll definitely keep tabs on this thread. Keep us posted.
Join the Revolution! http://www.ronpaul.com/
4cefed
Car: 92 240SX Coupe
03 SRT-4
Various Dodge POSs
Re: Powered By Ford
Postby alms24sebring » Wed Jun 27, 2012 9:04 pm
Awesome build out of the ordinary. I would have never of guessed that motor. The trans and the stick shift fit well too?
alms24sebring
'04 Nissan Sentra SER SpecV
Re: Powered By Ford
Postby BlackZenki82 » Thu Jun 28, 2012 10:50 am
4cefed wrote:I have been thinking about some kind of a v8 swap and I was trying to think of an all aluminum v8 for cheap. I'll definitely keep tabs on this thread. Keep us posted.
most MK8 engines can be had for $200-$500 from a local junk yard.
cobra crank/rods/piston take out set can be well under 1K, if you go that route
02-04 twin plate cobra clutch/FW (used) for around $3-$400
Transmission for around $500 (cheaper if you know where to look, i got mine for $75)
so if you're running a "stock" MK8 engine, and assemble the parts yourself, you basically have 300hp/300tq (sounds a lot like el es juans), that hasn't been beat on by some redneck, or teenagers first car. and it would cost you LESS than a SR on a pallet.
So far into my build, with all the parts I've accrued, including car/body/aero/supporting stuff, I'm right around the $2-$2.5K mark... you can't get a beat down LSx with trans for that cheap, and I'll prob end up making more power on the dyno, due to the fact that the motor most likely hasn't been beat on over the last 15 years.
BlackZenki82
Re: Powered By Ford
Postby 4cefed » Thu Jun 28, 2012 11:38 am
Thanks for the info. I have an s13 coupe and I'm trying to keep it sleeperish, no crazy body kits or anything.
I see the engine is about 30 inches wide, how tall is it? how long is it? I don't have a problem tubing the front as long as I can get the hood back down and some kind of radiator in there. My brother works in a salvage yard, so I can get engines and stuff cheap. Thanks again for the info.
4cefed
Car: 92 240SX Coupe
03 SRT-4
Various Dodge POSs
Re: Powered By Ford
Postby Driftnaut » Fri Jun 29, 2012 4:02 pm
This thing is going to be a monster! So aggressive looking!
Driftnaut
Car: 2005 Nissan Altima 2.5s
Re: Powered By Ford
Postby BlackZenki82 » Fri Jun 29, 2012 11:15 pm
Driftnaut wrote:This thing is going to be a monster! So aggressive looking!
*disclaimer* I've drank, and smoked a lot, just drove for the first time in a year (bro let me slide his s***).
But yeah, beers and bleezies aside, my end goal for this this, is to have an engine trans set up, that weighs maybe 100lbs more total than a KA, but have at least 300whp, and with some free flowing exhaust, 300+whtq on demand. That mixed with my but naked shell with a cage? To me, it would be the perfect balance of power/weight in a S14, not to mention the unibody frame twisting tq that would come on early. I'm not going pro, this is a hobby for me, so I'm pretty sure after my SR days, this s*** going to be a blast to just get out and shred with.
You can keep your 600hp+ drift cars.
/Inebriated rant.
Oh, Fords sound better than chevy, Piss Off. Ford sounds like a V8 should.
BlackZenki82
Re: Powered By Ford
Postby SX APPEAL » Sat Jun 30, 2012 12:56 am
BlackZenki82 wrote:
Driftnaut wrote:Oh, Fords sound better than chevy, Piss Off. Ford sounds like a V8 should.
Truth! [/alsodrunk]
Why spend thousands of $$$ on car that no run?
Parting out my build, getcha some!
Good judgement comes from experience, experience comes from bad judgement...
SX APPEAL
Car: 95 S14 KA-T GT3076
-might run someday...
95 Maxima Daily
-blown headgasket...
Re: Powered By Ford
Postby DMan II-40 » Mon Jul 02, 2012 10:49 pm
I haven't posted in a long time, but I had to cuz this build is bad a**!
DMan II-40
Car: 1995 240SX SE
Re: Powered By Ford
Postby splintercell » Tue Jul 03, 2012 4:55 am
dope...cant wait for updates/ subscribed :crazy:
ALLIANCE NISSAN- JASON MORALES
PARTS DEPT- 757-328-2708
www.sumospeed.com
splintercell
Car: 1989 nissan 240sx hatchback
Re: Powered By Ford
Postby h2v7 » Wed Jul 04, 2012 8:30 am
cool where is more. need now
h2v7
Car: 240sx s13
Re: Powered By Ford
Postby BlackZenki82 » Fri Jul 06, 2012 9:44 am
More is coming, just waiting on my buddies hoist and then I can start fabbing mounts/checking BMC/steering column clearance.
Also have a local buddy with a CNC machine, and table plasma cutter who said he'd make 10 sets of mounts for me, on the cheap...
Maybe otheres see the potential of this swap? Once simplified, it could be quite capable.
BlackZenki82
Re: Powered By Ford
Postby kouki munster » Fri Jul 06, 2012 3:10 pm
I have contemplated the same idea, just never have been able to get the time to even try and get the motor mounted in the test chassis. However, I would be interested in a set of mounts if you make some, of course depending on how far down and back what you come up with sits the motor, as I would much rather modify an oil pan then have to cut up my hood for clearance.
kouki munster
Car: 97 base 240
Re: Powered By Ford
Postby TurboSauce » Fri Jul 06, 2012 6:46 pm
Sometimes my pants randomly come off... This is one of those times
TurboSauce
Car: '98 Toyota Altezza RS200
Re: Powered By Ford
Postby PapaSmurf2k3 » Sat Jul 07, 2012 6:49 am
Looks good so far!
PapaSmurf2k3
Car: 1991 240sx coupe KA-T, 1997 Prelude, 2001 Miata turbo, 1993 240sx hatch
Re: Powered By Ford
Postby themadscientist » Sun Jul 08, 2012 1:54 am
Hearing the whining of the LSx fanbois will please me. Please continue with this very unique project!
CA18, SR20, and RB20 bellhousings for sale!
ca-rb-and-sr-transmission-bellhousings-t566183.html
themadscientist
Car: DR30 Skyline, 180SX, Daihatsu Hijet, NSR50
Re: Powered By Ford
Postby kouki munster » Sun Aug 19, 2012 9:13 am
Hmmmm............. deja vu.
kouki munster
Car: 97 base 240
Return to 240sx General Discussion
