sublime187 wrote:...that of course when there is a fluid loss the pump will be noisy. But he has no solution.
None of them ruled out a problem with the rack, although nothing is visible externally. The strange thing is that the problem was apparently fixed for over a week by simply flushing the lines with solution. Weird, because it's losing fluid somehow from somewhere, but simply cleaning the lines was a temporary fix.
That's scary that fluid is being lost but no one can find from where!
Racks usually don't go bad unless fluid change interval is abused. Generally the seals just start leaking.
What color was the PS fluid? Most PS "flushes" are simultaneous extraction and refill operation through the resevoir. If the fluid is nasty brown or black, then an actual flush through the low pressure hose must be performed to extract the gunk from the recesses of the rack and pump. I know the Sun machine can be used for this, but I really don't know how the BG machine works in this regard. The steering must be cycled lock to lock and held a few seconds at each lock to exhcange all the fluid.
While M1 ATF is a suitable fluid, TexasOil has told me that a seal conditioner must be used with it or they will shrink. It should be noted that BG does use a conditioner with its PS synthetic fluid when it performs the PS service.
Joe sells OEM new and Meridian rebuilt. One should know that the rack mechanism is machined to a few ten-thousandsth of an inch. Very precise.
