vin27 »
https://forums.nicoclub.com/vin27-u178376.html
Wed Apr 13, 2011 11:07 pm
Thanks for the good advice guys, and now I have a couple more questions!
Regarding ATF in AT's, I've heard that it's not good to mix old Mineral with New Synthetic, and in fact, even heard that if you have never changed your ATF, you are better off keeping the old fluid in there, than to refill it with new stuff and "shock" the system.
Regarding AFT in Power Steering, is it ok to mix Synthetic, with the old stuff that
has probably never been changed?
I've also heard that you should never hold the Steering at Full Lock, it also builds up more pressure in the lines, and so I do not do that.
All the best,
Vin
