power steering comes and goes
kelvin5638
Car: 1990 Infiniti Q45 30% tint nissan anniversary edition 18" wheels on 245/40/18 zrated tires
my power steering comes and goes sometimes I have it sometimes I dont and power steering pump was replaced two months ago.
elwesso
Car: 94 Infiniti Q45t 5 spd
2007 BMW M Coupe
2007 Infiniti G35 S 6MT
does it make any funny noises? how is your fluid level?
We will need some basic history on whatever is applicable to further diagnose the problem....Oh and welcome to NICO, the premier club for Q45 enthusiast worldwide... there, i snuck in my sales pitch...
bigdog76
Car: 1996 Infinity Q45
Mine was doing this about 3 years ago. I read some post on hereI end up buying a used complete odometer cluster. The entire cluster I picked it up for $50 shipped.
Pain in the butt to rip out the whole dash. I installed it and that solved the problem have not had a issue since. Go figure huh?
One thing to remember. I did this during the day with daylight of course.But when night time came and everything was reinstalled I turned on the headlights and noticed one of thoses little dash lights was out on my cluster.
The next morning I had to rip that whole dash out again not fun. Make sure all lights are working.
maxnix
Car: 1995 Infiniti Q45
1995 Infiniti Q45t
2000 Infiniti Q45
Could be belt and tensionser, could be speed sensor.
Maintenance history please.
Welcome to NICO.
Modified by maxnix at 12:09 PM 5/6/2008
bigdog76
Ya they told me speed sensor too I fixed that and it didnt help! But that was me.
elwesso
2007 BMW M Coupe
the important thing to know here is if the speedo goes out at the same time the steering goes out, and if there are any odd noises?
kelvin5638
yes i did notice that today that they were both out at the same time what is this?
kelvin5638
no funny noises and i also removed the old ps fluid and replaced with new i also noticed that the ps reservoir was filled with atf does that matter.
kelvin5638
just had tensioner and all belts replaced cuz the tensioner fell off cost me 860 bucks had to replace battery also included in that price.
maxnix
1995 Infiniti Q45t
2000 Infiniti Q45
kelvin5638 wrote:just had tensioner and all belts replaced cuz the tensioner fell off cost me 860 bucks had to replace battery also included in that price.
Wow. I hoped you got kissed too!
I am going for speed sensor. But let others chime in.
If you use ATF for PS fluid, it's good to also use a seal conditioner.
Haitian_King
Car: 1992 Black Infiniti Q45 /w TCS
1995 Black Infiniti Q45
kelvin5638 wrote:my power steering comes and goes sometimes I have it sometimes I dont and power steering pump was replaced two months ago.
My cousin had the same issue with his Q years ago. His was a leak I believe. He had to keep refilling it with fluid. From time to time, it would go out on him and he'd have the hardest time trying to turn.
elwesso
2007 BMW M Coupe
Ive seen more instrument clusters cause this problem then speed sensors. Id try and find a used cluster and see if that fixes it... From what Ive seen this is more common...
You can look at the voltage of the speedo sensor. If it drops out, then you know its the sensor. If it stays fine, then you know its the cluster.
chuy38
Car: 1996 Q45
have same issue. my body hooked up his gadget to the computer and said it was a speed sensor. we raised the rear end and the speed sensor looked kind of bent. Have not replaced it. Need to find out where to get one. 96 Q45t
maxnix
1995 Infiniti Q45t
2000 Infiniti Q45
chuy38 wrote: Need to find out where to get one. 96 Q45t
http://www.infinitipartsusa.com
Call them.
Q45tech
First study the way the system works and perform tests before replacing anything.
Inside cluster there is an integrated circuit that translates the pulse from speed sensor to 0-5 volts, once speed is translated to a voltage it feeds 5 different systems and each is isolated from each other so a failure in one won't bring down the others.
Since you have 2 noticeable failures the cluster has become intermittent from solder crystalization. Replace the entire cluster from 90-93 junker Q swap your odometer into replacement cluster to maintain reading.
Even 18 year old cars require electronics skills to trouble shoot. Might as well start learning now, as it only gets worse the newer the model.
