thedude45551 »
https://forums.nicoclub.com/thedude45551-u177801.html
Tue Jan 25, 2011 5:54 pm
Hello, ive got an extensive issue i wanted to bounce off you guys and see if we can make heads or tails of what im dealing with. i have been having issues with my 90 N/A 300zx for sometime now and have just recently got the funds to start work on it again. the issue being, between 1500 rpm and 3000rpm i get severe hesitation and loss of power. so much to the point, it begins to stall, and backfire. once i breach the 3000 rpm mark, it takes off like a bat out of hell. it even seems to idle kinda rough. when i free rev it in neutral, it revs just fine. when i put a load on the engine(drive it), that is when the problem manifests itself. ive recently replaced the injectors, fuel filter, and spark plugs, in an effort to fix the issue. the old injectors were completely shot, the new however all ohm out at between 12 and 13. the injector connectors and coil pack connectors seem to be in pretty rough shape and i can tell need replaced and cleaned. but i figure if that were the problem, it wouldnt free rev as well as it does. am i wrong on that? other than injectors, injector/coil connectors, spark plugs, and coils, all of which are things that can be easily tested. what could it possibly be? Vacuums hoses, TPS, knock sensor, cranks sensor? im just guessing things that are a possibility, from my past experience working on toyota supras and rx7s. any assistance you could render would be greatly appreciated. if there is anything you could think of that commonly goes out on these cars, that might cause this. im all ears. thank you
