I disagree with this a bit, the standard Vg30e has a higher comp rate than the factory Vg30et does it not? Higher compression combined with the factory boost levels will require more fuel than the original Vg30et map will call forevildky wrote: the tuning isn't necesarry unless you want to run larger injectors
Yes. Higher compression. No. It won't require a different fuel map. Using the NA motor, you will need the turbo injectors and ECU, but you can retain the stock fuel map all the way up to 12.5psi.svairman wrote:
VG30E 84-89+: Engine compression ratio of 9:1VG30ET 84-87: Single Garrett T3 turbocharger with a factory boost setting of 6.8PSI and an engine compression ratio of 7.8:1VG30ET 88-89+: Single Garrett T25 turbocharger with a factory boost setting of 4-5PSI and an engine compression ratio of 8.3:1
Actually, you'd need a second NA cross member to cut the passenger side ear off. You can't cut off the driver side ear and turn it around. Basically, the NA cross member is a mirror of itself. And basically (minus the steering rack mount), the turbo cross member is itself rotated 180*.evildky wrote:I know the M is similar but I'm thinking the Z31 crossmember will not work, just a theory, but you can always cut the mounting ear form the stock crossmember and flip it around and weld it back in to accomodate the turbo
the motor mounts are the same but the bracket that bolts the drivers side mount to the motor is a bit different but you can simply notch the n/a bracket, it simply neads to be clearanced to fit around the oil line banjo bolt that feeds oil to the turbo
If you're going to go that far, you're better off building a new one. It would need massive reconstruction. It would be like cutting off your left ear and putting it on the right side of your head.evildky wrote:I'm sure the mounting ear form the drivers side isn't the ideal part if you can handle cutting it off and welding ti back on I'm sure you can handle restructuring it a bit to fit
actually on the M i believe it puts it right where the ac sitsPerrenial Badass wrote:Actually, if memory serves SATAN makes a top mount for the passenger side. Puts it in the place of the PS pump. If you want to retain the AC that might be an option, it should be a lot easier doing that and fabbing up feed/return lines and a downpipe than having to chop up the crossmember. Even if you used the stock turbo at first, you could get everything running with a setup you wouldn't have to change much on when you upgrade the turbo.
