The thermostat fails open so it's not the cause of your high temp. How's your fans working? Are you hearing the electric fan switch on/off? Is the fan clutch operative and spinning at full speed at idle?mattd1979 wrote:I had been there about 10 minutes in the driveway..... I guess I'll be looking at swapping in another thermostat.......
I'm going to guess that she'll run nice and cool on the highway but as soon as you exit and get in stop and go traffic or sit in the driveway it's going to heat up. Fan clutch- Is the fan spinning at idle or barely moving? You can check it by loosening the belt and rotating the fan manually. There should be a lot of resistance and it should definately not spin freely.mattd1979 wrote:...... I am going to hookup my laptop to the car and drive to see how it does on the interstate.
......A few weeks back one day I left the car idling in the driveway for about 10 minutes and the temp outside was somewhere around the upper 90's. When I got back to the car to leave, I noticed the temp gauge was reading 3/4 of the way up......
Interesting numbers you posted and it looks like you're running 10*-15* warmer than you should be at idle. Did the electric fan go on/off at any time during the idle test?mattd1979 wrote:.......I thought about the clutch fan. I did hear the electric fan cut in and out and I had replaced my water pump back in february due to bearing failure.
I was mistaken in telling you to loosen the fan belt to check the fan clutch. No wrenching is involved. Just turn the fan blade by hand. If there's no resistance the fan clutch needs replacing. If you can feel it pulling back it's probably OK. I'm sure there's a more scientific way to diagnose it in the FSM but this "quick check" will get you started.goody94q45 wrote:.....You don't need to do anything to check the fan clutch except loosen one idler pulley......
