I replaced the brake booster on my car a few painful days ago. I found that it can be replaced in ~5 hours. Thats with all the right tools needed to do the job. I have removed and reinstalled some pieces of the dashboard on my car. So I am missing some nuts/screws and bolts which sped up removal.
Step one: Remove center window switch controls
Step two: remove the radio/HVAC controls trim piece.
Step three: remove the lower knee trim piece that house the drivers foot well light.
Step four: remove the two nuts and two bolts that hold the steering column up, Properly support steering column. Make sure one of the airbag connectors does not come off or break. On my car it popped out but I popped it back in. The airbag light blinked but reset following the procedure posted here:
http://www.nicoclub.com/archives/reset- ... light.html
Step five: locate and remove all 4 nuts holding the brake booster to the vehicle. Notice how I say locate. Well the nuts are not in plain sight especially the upper right hand one. I just used the lower right hand one as a guide.
Step six: once all the bolts are loose but still in the studs remove the safety pin and clevis pin on the brake pedal. Push the tabs on the clevis pin in as to not break it like me. The tabs are plastic I think.
Step seven: remove the two flare nut fittings from the brake master cylinder and then remove the two nuts from the master cylinder. Put a pig mat or paper towels under the lines before removing them so you don't take paint away from the dripping lines.
Step eight: remove the old gasket from the firewall and clean the firewall area where the brake booster was.
step nine: install new gasket and brake booster. Be careful of the brake lines so they don't get bent. Also be careful of the plastic brake line anti-vibration retainers.
Step ten: Depending on where you get your brake booster it may have the "U" shaped piece that the lock nut goes against and the clevis pin goes into already installed. If not you must count the threads on the old one you removed. Then re-install it on the new one.
But ever since installing the brake booster my front brakes are sticking. At least I think its just the front brakes. I checked the brake pedal free height and it is with in specifications. Any idea's?? I will remove the brake master cylinder tomorrow weather permitting.
I will take some pictures when I get around to it. I know this is not a job I want to do again!
