if you can start the car at least every week for 15mins, that would be great. try to roll it around. tires that stand around with weight on them, will get something called DRY ROT.Sadequr2002 wrote:Sorry for little latE reply i in south America For a month I have service mantainnance ArOund sep 25 I Will leT them knw .Tnx for all reply help . One more thing , I left the car in garage for a month is that ok for it tnx all
Wow, that's good to know. I'm glad I signed up here since I'm learning a lotImStricken wrote:if you can start the car at least every week for 15mins, that would be great. try to roll it around. tires that stand around with weight on them, will get something called DRY ROT.
Tnx I will start Once a week tnx for ReplyImStricken wrote:if you can start the car at least every week for 15mins, that would be great. try to roll it around. tires that stand around with weight on them, will get something called DRY ROT.Sadequr2002 wrote:Sorry for little latE reply i in south America For a month I have service mantainnance ArOund sep 25 I Will leT them knw .Tnx for all reply help . One more thing , I left the car in garage for a month is that ok for it tnx all
Tnx again keep learning I will Let someon knw to move tO move the car but I don't Like My friend How they Behave with car they alWays just hit the Gas and go but I take time Start the car wait for car to warm up little then slowly drive . Some says always warm up the car then go Some says warm Up whiLe drIving Who should I listen plz helpImStricken wrote:every time you start a car, it takes about 10mins of running before you replenish what you took out(for the initial start)
but its important to roll the car around, and to try and change the spot the car is parked on. you dont want to keep weight on the same spot on a tire.
